โJun-19-2020 06:31 PM
โJun-20-2020 12:21 PM
โJun-20-2020 08:41 AM
โJun-20-2020 08:16 AM
โJun-20-2020 05:50 AM
โJun-20-2020 05:46 AM
enblethen wrote:
Did you check the ground where it attaches to the frame?
I did not see what type of rig, make and model?
โJun-20-2020 05:30 AM
Bud
USAF Retired
Pace Arrow
โJun-20-2020 03:27 AM
โJun-19-2020 08:27 PM
MEXICOWANDERER wrote:
Find the exact spot where the converter enters the power to the fuse panel.
At that exact spot, start testing backward to the batteries. I've got an ESPN feeling you are dealing with a flaky negative junction. My crystal ball is 74 years old so don't throw tomatoes if it turns out to be on the positive cables.
โJun-19-2020 08:05 PM
โJun-19-2020 07:52 PM
2oldman wrote:D MAX wrote:I need clarification on this.
On DC (2 x 6V) lights are good, power shows full (also metered at batteries 13ish). When the water pump kicks on it dramatically slows down,....Checked the voltage at the batteries while this happens and it shows a slight drop. On shore power no problems at all.
"On DC". Does that mean on batteries alone without the converter running? 13ish is not the resting voltage of any battery, so it sounds as if the converter is on, but then later you say..
"On shore power..." (which runs the converter).
thanks
โJun-19-2020 07:44 PM
DrewE wrote:
I think you probably have a poor connection somewhere between the battery and the DC distribution panel, quite possibly at the main self-resetting circuit breaker for the battery (or possibly inside that circuit breaker). A poor connection there would not only cause a voltage drop, but would also make the circuit breaker warm up a good bit and so trip at well below its rated current. That said, there may be a poor connection in many places, and it could be on either the positive or the ground side. Go through and check that all the joints are clean and tight, and the wires have not corroded away (particularly those attaching to the battery).
โJun-19-2020 07:39 PM
โJun-19-2020 07:04 PM
