PVC Pipe Solvent/Cement, How do you Prolong in storage ?
Kamphiker
Any tricks in keeping shelf Life ?
I purchase the smallest size containers for occasional use. By the time I get to another project I have to throw out the last purchase & buy new.
It makes simple cheap projects a lot more expensive (& a PITA to run out to HD / Lowes etc)
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
29 REPLIES 29
Chum_lee
It is the air in the can that kills it !
The cans have very little air when they come out of the factory and may even be vacuumed sealed. Add air when they are opened and life gets shorter.
You are half correct. PVC cement has two basic parts. Resin and solvent. When you open the can, air enters and contacts the resin. It begins to cure. (harden) At the same time, the volatile solvent(s) escape out of the can. You smell the solvents. The solvent (THF) is important because it dissolves (melts) the pipe and the fitting so that the two eventually fuse together. The resin fills any voids between the two making the joint water/air tight. The solvent portion also contains thinners (acetone and cyclohexanone) to get the viscosity of the cement correct for the ambient temperature, the pipe material/diameter, and cure time.
Chum lee
Dtank
MrWizard wrote:
Yep, I just consider it part of the price of the repair project
Ditto that.
Buy only small, new one for new project. If it turns out your old can is still OK, don't open the new one - save 'til next time....:W
Side note:
The plumber "thing":
Forget the brand....
Next time you are in Loews (not sure if HD has it) - there's a wood filler with labels that read "normally" - however the "pry-off" lid of
the can will be *on the bottom*......the can is stored upside-down, at least until *you* store it the other way round.
And yeah it's a - "use in well ventilated area" - guess the logic is the same as the ABS/PVC hint to keep it from drying out.
philh
interesting idea to vacuum seal the can. I might have to try that. Also be nice if they sold like a single use tube of material.
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
cavie
with 50 years of PVC glue experience I can tell you you can not store it for long periods. Just buy small cans. Check it before your next project and buy new small cans if need be.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
jjrbus
I just had a can last an abnormally long time and I have no idea why?
I have thought of giving the can a spray of aerosol computer cleaner in a spray can before putting away.
Now I see they have the solvent in a spray can, may try that next time.
RedRollingRoadb
So and I'm the only one that has had the lid glue itself shut so tight I couldn't get it off? Only needed enough for two joints so I just punctured the bottom.
SoundGuy
I've never bothered trying to prolong the life of PVC / ABS cement which I can buy in small cans as I may need it but with larger containers of paint, drywall mud, etc, I find that placing a layer of clear plastic film over the top surface of whatever is remaining in the can goes a long way to preserving the contents in it's original state. I've used drywall mud and paint several years after original purchase and it's been just as good as when I bought the container new.
2012 Silverado 1500 Crew Cab
theoldwizard1
beemerphile1
Seal-a-meal vacuum sealer? I haven't done it with PVC cement but have with other items. Put it in a bag, suck, and seal.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Lantley
How much is the small can $5.00? Maybe less? Consider it the price of doing business.
LarryJM
joshuajim wrote:
I give the can a shot of argon from the TIG to displace the O2. Seems to keep a long time.
Along the same lines ....
Put a layer of the solvent (Acetone/Methyl Ketone) on top and DO NOT MIX ... It won't last forever, but will extend what is left in the can by preventing air to be in actual contact with the cement liquid until that sacrifical top layer of solvent evaporates.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
joshuajim
RVing since 1995.
352
Seal the threads with PVC glue when finished with the job.
It does work !!!!!!!!!!!!!!!!!!
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
