Oct-07-2013 08:07 AM
Oct-11-2013 04:52 PM
Oct-10-2013 03:58 PM
Oct-10-2013 03:38 PM
Oct-08-2013 07:42 AM
dougrainer wrote:
This post is WHY it is important to give year/Brand and model of appliance and RV when asking for help. There are 2 flame sensor types and both Norcold and Dometic have used both over the years.
1. Is the Thermocoupler pictured in the one post
2. Is what I call the flame sensor and is also the spark electrode. There is NO thermocoupler at all in the standard sense.
One poster talked about and had a pic of what he thought was a refer thermocoupler. Well yes, 25 to 30 years ago. The Metal tube type thermocoupler used on Dometic has 2 wires with a spade terminal on each wire and connects to the main control board. BUT, Dometic uses both types and it depends on the model number. Doug
Oct-08-2013 05:15 AM
camperpaul wrote:
The flame detector (thermocouple) may be defective.
Oct-08-2013 05:04 AM
Oct-07-2013 04:27 PM
j-d wrote:
When the furnace goes to light on LPG, the Logic Board sends power to the Gas Valve to open, and STAY OPEN long enough for the ThermoCouple (TC) to get hot. Then the board takes the power it provided away, relying on the power produced by the TC to continue to hold the valve open. No TC output, gas valve flops shut, LPG flow stops, flame goes out. Our early model Dometic (RM763) would actually cycle. You'd hear Clunk>Spark>Pop>Flame>Click>Flame Out>...Repeat...
In this picture, the connector that attaches to the gas valve is in the middle of the loop. The Loop Looks like copper tubing and the Nut Looks like a gas fitting nut. But they are NOT. The tubing is one side of an electric "cable" and the other conductor runs down the center inside some insulation. Finger tight plus maybe 1/4 turn is all it takes to make up the connection. There's no LPG there to leak, so it doesn't have to be tight. And too tight will short out the connection and the ThermoCouple won't work.
EDIT: Doug was typing while I was. Suggest going with his timing on the cycling of the gas valve. As I remember, when our old Dometic was doing that (and it turned out to be a bad TC) the cycle was less than a minute.
Oct-07-2013 04:25 PM
dougrainer wrote:
1. There is NO pilot light. That is the regular flame
2. Yes, it could run 2 to 4 minutes if the Thermocoupler was bad, but that is rare. MOST flame sensors shut down after 45 seconds, UNLESS you are not watching and the refer does a triple start. Most refers have a tri start ignition cycle that will light, then shut down after 45 seconds, the wait a few seconds and relight and if it shuts down will wait a few seconds and then try the 3rd time. If no flame sense after the 3rd try it locks out and the check light comes on. THAT can be your 2 to 4 minutes. IF that is not the case, then a flame thermosensor can have an intermittant operation and then shuts off randomly.
3. NO FUSE will cause this problem. It is either the Flame sensor or the main control board. 9 time out of 10 it is the flame sensor, unless you have a Dometic refer built from about 1992 to 1998. Doug
Oct-07-2013 01:20 PM
Oct-07-2013 12:57 PM
Oct-07-2013 11:58 AM
Oct-07-2013 08:51 AM
CaptRick wrote:
If the thermocouple were bad would the pilot still light and run for 2-4 minutes?
Thanks
Oct-07-2013 08:35 AM
Oct-07-2013 08:28 AM
