Jun-04-2022 12:20 PM
Jun-08-2022 05:43 AM
Vintage465 wrote:StirCrazy wrote:Vintage465 wrote:wa8yxm wrote:Vintage465 wrote:
I have four 6v flooded old school golf cart batteries. I read up on the manual. What it actually says is there is a button you can push on the circuit board to "arrest" it(they don't recommend doing this) in what ever stage you like. Then after some event...like the end of the stage/cycle, it will default back to the algorithm........anyway, I don't see why I'd do that, but that's the way I read it.
I read the Wizard manual a bit differently but the effect (end result) is the same.
I do not recall seeing a LiFePO4 mode but they did enter into a deal with Battle Born to produce a converter for LiFePO4s and they may have added that mode to the wizard since (Would make sense to do so)
No matter what model you have no matter if wizard is built in Like 4600 or 9200 or plugged in (9100 which I had) same wizard.
Those with built in have an optional dongle. That's where the button is.
You likely read it more accurately than me. I just saw that you can select a particular stage by pressing the button in a sequence and based on the flashes choose a stage and at some point it will automatically default back to the Charge Wizard being in control. And the Charge Wizard can be disabled by unplugging and removing the pigtail that connects the mother board to the fuse panel. Either way, I'll never mess with it unless it starts frying my batteries. I don't spend any time regularly plugged into shore power on a genny. So in reality this is all great stuff for someone else.
I have had one PD with the plugin charge wizzard, and 4 with it built in. I have never seen a button on them so this is interesting. I just put in a whole PD load center into my camper last sumer and don't recal any button either.. weird..
just went on there site, if it has a built in charge wizzard there is no way to interact with it. it is all actavated automaticly by the voltage of the battery.
Steve
Seems to me that PD makes a lot of different stuff and they may not all have the same features. Here is what mine says and has about the mysterious button
Jun-07-2022 07:15 AM
Jun-07-2022 06:05 AM
Jun-06-2022 06:56 PM
No...As shown here there are different charge modes. The software controls what charge mode the PD is in, unless you push the button and change it. All the Wizard does is let you move that button to a more convenient location.
The main use case is if you are boondocking and using the batteries and have limited generator time, you can use the wizard to force the PD into boost mode and get more battery charge from your gen run time. Other than that, there is no need to "turn it off", just leave it alone.
Jun-06-2022 06:21 PM
Jun-06-2022 12:36 PM
Steve
Jun-06-2022 11:21 AM
Jun-06-2022 11:17 AM
Steve
Jun-06-2022 07:04 AM
Jun-05-2022 09:59 AM
Jun-05-2022 09:53 AM
Jun-05-2022 09:03 AM
Jun-05-2022 07:38 AM
Jun-05-2022 05:58 AM
