The Official unofficial CPE 2000i Generator Thread
pritch272
8/1/2010 edit: Thread renamed at the suggestion of the Professor.
Renamed from: Champion Inverter and Remote Gens Promo on CPE's web site)
3/22/2011 edit: Thread renamed ...
Renamed from: Official CPE 2000 Watt Inverter Generator Thread
3/23/2011 edit: Thread renamed at the suggestion of the Professor.
Renamed from: (Un)Official CPE 2000 Watt Inverter Generator Thread
Inverter Available August 2010
Remote Available July 2010
2007 Keystone Laredo 29RL, 2000 Ford F250 7.3 PSD, Firestone bags, Pressure Pro, 16" Michelin XPS Ribs, MorRyde Pin Box, Dexter EZ-Flex, PI EMS-HW30C, Dirt Devil CV950 Central Vacuum, 2000W AllPower by Kipor, 4000/3500W Champion C46540
2,927 REPLIES 2,927
DudleyDone
Thanks for all the kind replies. I did indeed check the usual items such as gas cap switch, oil level, fresh gas. I actually cleaned the spark arrest screen about 30 hours ago, so it's ok. It's a no spark at the plug issue. It may be a dislodged connector somewhere, I don't know I looked pretty extensively. I probably spent somewhere between 2-3 hours taking it apart and trying to pinpoint a source for the problem and basically came to my limit of time invest ment into a problem I am pretty confident I did not cause. I am officially declaring it fubared and Champion can do the autopsy if they wish.
I really liked this generator and am torn about getting it replaced for another vs trying the Honda koolaid.
canadiankid
DudleyDone wrote:
Back to Costco it will go.
Got to love Costco for that reason as well as many others. I personal would just buy another one and then you get 2 years worth of warranty to see how it lasts. You seem to put a few hours on your generator so you should know if you have a good one before the two years are up.
Just my 2 cents.
Don.
2010 Tundra Crewmax 2WD 5.7
2009 Greywolf 22BH
MrRchitty
Fuel cap open? I've forgotten that myself. Or how about the spark arrest screen? Is it clogged?
Randall J. Chittenden
CT
Fire/Medic
Former Auto Parts Sales 12 years
DSchmidt_2000
professor95 wrote:
If you open the Kill-A-Watt meter, you will find a 15 amp ceramic cased fuse inside. 99 to 1 the fuse is blown.
It's a 200mA fuse and indeed it is blown.
professor95 wrote:
I hope you remembered to check the engine oil. Symptoms you describe are common when the engine oil gets low and the protection switch shuts it down.
he did
DudleyDone wrote:
all I could do is visually verify that I had enough oil, spark plug/wire seemed ok,
-_dwh_-
professor95 wrote:
DudleyDone wrote:
I write this from the cabin with some sadness as it seems my little champion inverter has died on me with just a little over 153 hours on the clock.
When I got up to the cabin this weekend. It fired up for about a minute, then it ran rough and stopped and won't start now.
I spent the better part of a couple of hours taking her apart and determing fuel and flow was ok and that it appears to be an electrical problem, no spark. Not having my multimeter with me, all I could do is visually verify that I had enough oil, spark plug/wire seemed ok, and all the electrical connections appeared intact.
I have been running my champion 3k non inverted genny for the last 36 hour. Gosh that generator with close to 800 hours is a real reliability champ. I just wish it was not so much louder and thirstier the inverter.
I definitely see another 2k inverter in my future just not too sure it's going to be a champion as I am obviously disapointed with my inverter's early demise.
Yes definitely. My little 42421 is VERY sensitive to low oil. I actually have to add a bit - like 1/4 ounce or less - with every tankful. When I forget, it starts up and then dies in about 10 seconds.
professor95
DSchmidt_2000 wrote:
I did also test to see how it could start a circular saw - which it did both with ECO throttle ON and OFF, BUT it did take both of my Kill-A-Watt's out of commission.
Replace the fuse (or simply take it out and put in a jumper wire) and it should be good as new again.
Professor Randy T. Agee & Nancy Agee. Also Oscar, the totally ruined Dachshund.
2009 Cedar Creek 5th Wheel - 2004 Volvo VNL670 class 8 MotorHome conversion as toter.
Turbocharged, 12L, 465 HP and 1,800 ft. Lbs. of torque.
professor95
DudleyDone
canadiankid
Just fired mine up today for the first time (first pull). Charged the battery and ran the microwave at the same time with ECO on. Fridge, Charger and Microwave turned the overload light on but kept all 3 going for the 15 seconds that I ran the microwave. My battery wasn't drained so I don't know how much power the charger was taking (ran at an idle with no microwave and just off of idle with just the fridge and charger). As the engine was running it did have a very small hiccup every about 10 seconds or so.
My build date was Nov 06/10. Overall I am very happy.
Don.
PS. don't think that just because the manual said it will take 400ml of oil that it will. mine poured out at about 375ml (must have had some left in from the factory).
2009 Greywolf 22BH
Old___Slow
DWH,
Best post of the day I've read out of maybe 200. I'm really taken with the Champion C42431. The C46540 I have had now for 4 years, I do believe with my dimming eyes, I could take it apart and re-assemble it with no problem. CPE has always had on hand any part I've needed. Only two thus far. Not counting A/C, the C42431 should be just great for camping. Fairly light and not to heavy. Maybe I'm just to darn old but the tried and proven oldies are right up my alley.
The 6000 btu A/C I mentiond for use with your gen was in a post by Prof. AFAIR he has used the 1200/1500w Champ with success with the 6000btu A/C. I may buy both soon for use in a shed up at the lake resort where I keep my MH. No juice close to the shed area.
-_dwh_-
Old & Slow wrote:
Perhaps DWH could give us some idea about his 1200w Champion C42431. It also has the 80cc engine. Will it spin up a 10a saw?
Possible, but unlikely, that I will be doing any full load tests. I bought it just for charging the aux battery in my camper and so far that's all I've used it for. I had purchased the Honeywell because I was thinking of putting a/c in the camper, but then after adding fans, I decided it didn't need it.
Some years ago, I decided to "simplify my life". I was a single father, and when I began to see the light at the end of the 18 year tunnel I knew I would want to travel often, and travel light, so I jettisoned all non-essentials. These days, the only power tools I have is a Ryobi kit with drill, sawzall, small circular saw and flashlight - all 18v battery operated. I added the 18v angle grinder and a car charger. The whole kit fits in a box the size of a suitcase, serves my needs for the rare times when I need it and is easily portable.
At this point, I don't actually own a garage full of stuff (like I used to), and so I have no way to setup a test lab. ๐Ÿ˜„
I'm old & slow and me eyes need some light on the subject of 'why buy some new finagling electronic moduled gen?
I think noise is a key issue. My little 42431 is certainly louder than the HW was; Though it seems to have better motor mounts (isolation) and vibrates the camper less than the HW so it's less noticable inside the camper, it is certainly more noticable outside the camper.
A couple of weeks ago I was camped near a rock face and the echo made the bloody thing seem twice as loud (outside the camper). If I was the type of fellow to camp in camp sites where there are other people around (I'm not), then I would -very- seriously consider going back to an inverter gen just because of the noise.
As for the a/c. I believe the poster who bought an a/c unit to cool the camper shell on the back of his truck to keep his dog comfortable spoke of buying an 8k btu unit...
Well, that's a problem. When I was thinking of adding a/c to my camper, I did quite a lot of research and the unit I was thinking of buying was a Frigidaire 5,200k btu. That particular unit had a SEER of I think 11, and actually used less power than the 5,000k btu Frigidaire unit that had a SEER of 9.
I contacted Frigidaire support asking what the startup load of that unit was, because I was thinking of running it from a generator, and received this information:
"Electrical Information
Voltage 115
Amps - Cooling 4.5
Watts - Cooling 475
Starting Amps 11.5
Starting Watts 1,322.50 Note: Generator must be capable of
handling this amount of wattage for start up plus whatever else is on the generator.
Fuse/Breaker (Amps) 15
Power Cord Amps Min 13"
I had also asked what exactly was the "Low-Voltage" startup listed in the specs for some Frigidaire units, and the answer was:
"However to answer your question the fan comes on first and about 3 min later the compressor comes on to keep the starting wattage down. The wattage I gave for start up is absolutely required or it could damage the product."
The model number of the unit I was looking at was FAA055P7A and it was sold in many places for around $150. That was a couple of years ago, and I'm not sure what is on the market today.
At that time, I was also looking at RV a/c units, and I saw two different types of "hard start kit". Both types add an extra starting capacitor, but in one type, the capacitor has a "timed delay" which I understand causes the capacitor to not fire for a few seconds, in order to give the fan time to spool up before the compressor starts.
I can see that there could be an issue when using the timed delay capacitor; If the hard start cap is simply piggybacked on a normal cap, then the normal one would fire immediately, while the secondary would fire some time later.
For that reason, I think if using a hard start capacitor which has a timed delay, that one might have to -replace- the existing cap with the hard start cap rather than just piggybacking onto it. Or, perhaps both must be time-delay caps.
YMMV.
Old___Slow
Nova Scotia Campers wrote:
Lachaine wrote:
I receive a email from CPE and the latest software (400ms) has been added to the product, starting 1 NOV 2010.
All units after Nov 1st 2010 production have the latest software upgrades. We began during Sept. deciding what to increase the load potential to, and it was actively included starting Nov. serial nos.
My comment on the new model with 12v charging plug.
If it is the same as Honda, the 12v is not controlled, no charging controller, if you forget your battery plugged, well you will fried your battery. ( I did not see any generator with charging controller, except, maybe the one with a starter)
I was asked via pm what the serial numbers were on my two cpe 2000i's which are both 19th of November builds. As my previous post said, I am able to charge the RV Battery and run the microwave at the same time, with one champion. I was also running the pump as well as I was flushing out thewater line anti freeze. Lights and radio were on as well. My converter charger is a Parallax 7155, and my microwave is a Hamilton Beach MW900BK for what its worth. By the way the gen was in econ mode. If the aboce is true then I have the latest programming. With the Champion, I am a very happy camper ๐Ÿ™‚
This post should set the bar for all. The 55a Converter/Charger could go as high as 900w input. The 900w MW could go as high as x2 input, way over the rated 1600w for the Champion 2000i ~ These two items are a 'hard go' each, for the Inverter gens, period. If others don't have the same results, maybe they should return their unit/units to the store for credit, to be 'happy campers'... The way I understand, CPE, only offers self help or Service Centers for repairs.
NSC,
From your profile you have been RV'ing for twenty years. Did you own other gensets? If so, I assume you are the well experienced happy camper. Perhaps you will share some other gen knowledge. I see only two posts and both are posted here, so welcome to the thread.
Nova_Scotia_Cam
Lachaine
professor95
Wayne Dohnal wrote:
Minimum current when switching the load on at peak voltage? Makes me feel like I'm in the twilight zone. This defies simple logic, which is probably why I went into digital electronics instead of this analog, inductive, reactive hocus-pocus that defies understanding. Reminds me of the horrors of Mr. Maxwell and field theory. End of rant.
For a serious question, the soft start on page 10 of the ST app note doesn't have anything in common with the RV air conditioner soft start capacitors, does it?
Wayne,
I'm not sure what soft start capacitors are. Truthfully, I have only known the term to be simply applied as "soft start".
While I grew up in an analog world and taught primarily analog electronics, I am not and was never anything close to an expert on all the technologies related to electric motors - be they AC, DC, single phase, three phase or what ever. I was introduced to SCR's and Triac's back in the early 70's as a method of theater lighting control that replaced auto-transformers and resistor coils and then slowly began to assimilate them into other analog projects I was working on where fast acting triggers and switches were needed along with motor speed controls.
I have not seen a detailed schematic diagram for the soft start control board used in some of the newer RV air conditioners, but I would not be at all surprised to find that the process described on page 10 of the ST application is indeed closely related to what is being done. I have also been under the impression that the term soft start was being universally applied to scroll refrigeration compressors vs. conventional head-on piston & crankshaft compressors. The scroll or screw compressor of course starting with minimum head pressure that slowly increases as motor speed begins to rise.
Then we find the term soft start technology or SST being used as part of battery to AC inverter technology which, once again, brings us back to the application presented on the referenced page 10. This implies that we can easily include soft start circuity on either the delivery or receiving end - which again makes perfect sense to me.
Maybe someone with more experience in motor controls and starting circuits is reading that will chime in? For me, it's time to go to bed - good night :Z
