Thumb wrote:
The start capacitor is only in the circuit during start up, then is automaticaly disconnected
The run capacitor stays in the circuit as long as the compressor /fan motors are running
Yes. Compressor and Fan in these RV A/C units are "PSC Motors" and I looked up this definition:
A permanent split capacitor (PSC) motor has neither a starting switch, nor a capacitor strictly for starting. Instead, it has a run-type capacitor permanently connected in series with the start winding. This makes the start winding an auxiliary winding once the motor reaches running speed.
In the RV A/C units, this means TWO RUN Capacitors, one for Compressor and one for Fan. If there's also a START Capacitor, it supports only the Compressor.
Our Mach 15 has a START Capacitor connected to the Compressor RUN Capacitor. It's controlled by a "Potential Relay" which I'm told provides better management of the Start Cap than the less expensive PTCR device (like SUPCO SPP6 has) and even the "electronic" versions (like SPP6e has), so I left it in place. FYI, in addition to the spare RUN cap, I have an SPP6e aboard as a spare Start Cap. "Start Assist" is probably the better term, since it's a Cap Plus a PTCR, Relay or Electronic switch.
@SVCJeff - YES, I suspected Frosting too. So when it was in its failed state, right after quitting, I had my tools in a bucket ready to go. Bolted for the roof and pulled the Shroud then Evaporator Cover. Clean and dry. From there, jumped into the Capacitor.
@GordonThree - I left the OEM Compressor Run Cap in place and moved the wires to the HERM (Hermetically Sealed, meaning Compressor) terminals of the two-way spare I had. Didn't connect FAN, and left the unit that way. When I get home, I'll clean that installation up by removing Old and securing New in place. When I do, I'll warm the Old and test it again.
This reminds me of testing TV Tubes with my dad as a kid. We'd go to (drug store as I remember, can that be right) and use the Tube Tester. Call the TV Tech when we couldn't find the problem. He had a caddy packed with new tubes, and one of those usually fixed it when our old one tested good. Name was Roy Ong and Roy explained that Testing and Using were two different things.
EDIT: This A/C does not have a Wall Thermostat, so NO Frost Sensor. That makes Freeze-Up a real concern. We have to run on High Fan all the time or it will frost over. Just wasn't the case this time...
