TST507 TPMS Saves The Day
allen8106
Good afternoon RV Forum friends. Just wanted to post a topic here for those of you not convinced that a TPMS on your RV is worth the effort or cost.
This past Saturday night late we returned from a 2000 mile round trip to Mesa, AZ to visit our youngest daughter. The trip down went very well without a hitch. The trip home had a slight delay with a low tire that I was alerted to by my TST507 TPMS I installed back in 2012.
I never drive over 65 mph because the 15" Maxxis tires are only rated for 65. No harm I prefer that speed. In my opinion anything higher just adds to the damage to your rig by the continuous earthquake of traveling of fair highways. Saturday afternoon we were traveling east on I40 just west of Santa Rosa, NM. Suddenly the TPMS alarmed and told me the right rear 5ver tire was down to 64 PSI. I normally air them to 70 cold and have the alarm set at 65. I watched a few more seconds and the pressure continued to drop and was at about 56 before I could get pulled over to the shoulder. I put the spare on, moved the TPMS sensor to the spare and went on down the road. At the next truck stop I dug out my tire pressure gauge and the tire I took off was at 41 psi.
Needless to say the TPMS saved the tire and considerable damage to the 5ver.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
15 REPLIES 15
pawpaw47
I've had my 507 for almost three years now, and had my first "save" last week. The alarm started going off and I watched as the pressure on the passenger side rear tire began going down. Yep - I had a flat!
2015 Starcraft Autumn Ridge 329BHU
2015 Starcraft AR-One 18QB
2014 GMC w/6.2L & max tow pkge.
allen8106
I took the 5ver tire in for repair today and they found that the high pressure, metal/rubber valve stem had failed. I did manage to find a #17-428 all metal valve stem at O'Reilly's that fit the .438 diameter recessed hole which I had not been able to find in my previous searches. I'll be replacing all the other high pressure stems with these new #17-428 valve stems before the next trip.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
joshuajim
After 21 years of towing without TPMS, I decided to get a 507. First trip with the new system about 2 miles from getting on I-40 near Needles CA, the alarm went off. Found the only asphalt shoulder on this secondary road about 200' ahead and pulled over. Fifteen minutes later we were on the road again. Turns out that the 4 year old Maxxis had a separation, probably from a road hazard on our miserable desert so called roads (they occasionally have paving between the continuous pot holes) :B
RVing since 1995.
allen8106
Terryallan wrote:
So. I have a question. Do you have to install metal valve stems to use the TST 507? Or can you just install the sensor?
At the time of the original install I coud not find any metal valve stems that fit my wheels. I opted for the metal re-enforced (high pressure) stems. They don't flex as much. So far in 5 yeas I haven't had a stem failure. Just within the last few months I've found a metal stem I think will fit, I'm going to order them and see if they do fit.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Luv_Campin
I've had one tire failure on the road, and it was caused by a rubber valve stem with a flow through sensor. I had thought that I was living on borrowed time with those stems. Went later that week and had metal valve stems put on. Made it with about two and a half years with the rubber stems with the sensors on there. Lesson learned.
2007 Ford F150
2012 Keystone Summerland 2100RB
one bossy dachsund
1 short wife and 1 short dog
BB_TX
At one time TST said metal stems should be used for the flow thru sensors, but were not required for the non flow thru. Don't know if that is still their position or not. The flow thru sensors are larger, and I suppose heavier, then the non flow thru. I have had the non flow thru on rubber stems for 7 years and no problem.
Lynnmor
edatlanta wrote:
It seems I didn't install the sensor tight enough and it leaked down enough overnight to trip the TST507 alarm. How far would I have driven before I noticed a shredded tire if the 507 wasn't there? Who knows, but I won't drive anywhere without my TST507.
So the system gave you a flat tire and it saved the day by telling you it flattened the tire?
I had a tire go down from a 507 sensor leaking as well, so the system does have its faults. That sensor is very sensitive on how much it should be tightened.
Ron3rd
Highly recommended to go with the metal stems. I asked TST the same question years ago and they told me I could use the rubber stems if I wanted. I did not like the flex I was seeing with the rubber stems so I changed to steel stems.
Equilizer Hitch
Honda EU2000
brulaz
BobsYourUncle wrote:
You would think I'd be smart enough to learn from all you guys and buy a TPMS myself.....
Nope! Haven't done it yet. What am I waiting for? Hmm good question. I know I should do it!
Most wait until they've had an "incident" themselves.
Like me.
Pulled into campground, noticed one tire was near flat. Which means the other tire on that side was carrying all the weight on that side for who knows how long.
It was close to time for new tires anyway, so had them use metal valve stems and ordered a tst 507 set. Works fine once you get it set up. Instructions were a little confusing.
And now I don't have to go out and check my tire pressures by hand!
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
edatlanta
The only "save" I can remember in 6 years with my TST507 was after being evacuated from a state park in Panama City, FL due to a hurricane. I moved 30 miles north and waited it out. The night before the return to Panama City I checked all 4 trailer tires for pressure and reinstalled the sensors (non flow through). The next morning while leaving my site the alarm went off for my right front tire. I had moved about 50'. It seems I didn't install the sensor tight enough and it leaked down enough overnight to trip the TST507 alarm. How far would I have driven before I noticed a shredded tire if the 507 wasn't there? Who knows, but I won't drive anywhere without my TST507.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Nice report! Good when a possible mess and damage is avoided.
I have had 3 catastrophic tire failures since 2003. One of them totaled my Prowler. 2 others did considerable damage to my Sportsmen.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
Terryallan
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Ron3rd
Love my 507, going on 5 years now.
Equilizer Hitch
Honda EU2000
loggenrock
I credit 3 "saves" to my TST TPMS over the years! Definitely worth the investment!!! ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
