Update on hot hubs on first trip
rtaylor0830
I made a post a couple days about how hot two of my hubs felt after my first trip with my new camper. I just returned home and measured the temps of each hub with a thermometer after the 2 1/2 hour drive the two on the drivers side were between 100 and 120 degrees the passenger were about 80-10 degrees. My question is I have a toy hauler and I keep it to the drivers side of the garage so I have more storage space is this an issue and would you be worried about these temps or are they ok.
11 REPLIES 11
wnjj
Edd505 wrote:
rexlion wrote:
janstey58 wrote:
x2, LOL!!
X3! Funny how the brain supplies info that it expects.
X4 hot tub????
You're actually x5. I was the first x3.
Edd505
rexlion wrote:
janstey58 wrote:
x2, LOL!!
X4 hot tub????
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
rexlion
janstey58 wrote:
x2, LOL!!
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
wa8yxm
ScottG wrote:
I have found that the side in the sun is always 10 to 20+ degree's hotter.
True story:
I use a "Gen-turi" Generator exhaust extension.. Well one weekend I was providing electricity for an "Event" and we were set up in a park. The park "Ranger" (representive) ask how hot the pipe got... At that point the Genny had been running for at least an hour.. I went over and wrapped my hand around it and invited him to do the same (Very warm, Think hot bath)
Well one day at a Wal*mart it was HOT, I mean HOT, so I hooked up the Gent-turi fired the genny to run the Roof A/C's for Kitty and Katty (Amber and Alex our house cats) the Genny was on the south side of the RV, overheated and shut down (House did not overheat) Even with the genny OFF the black pipe was too hot to handle. Just from the SUN.
So yes the sunny side gets HOTTER.. big time.
wnjj
kohai wrote:
..... totally misread the title of this post. I thought it was about hot tubs.
Same, and was really surprised when I starting reading about 2 of them!
janstey58
x2, LOL!!
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
kohai
2014 Primetime Crusader 296BHS
2015 GMC 2500HD Denali
ScottG
If you have a real problem like grease on brakes or a failing bearing, you likely see temps of 160 degrees or better.
At least that is my experience.
But do lift the trailer and check for brake drag (there should be some but not too much), hub looseness and bearing smoothness.
DutchmenSport
On your previous post, you had several suggestions to rise the camper and spin the wheels to see if you have any drag, meaning the brakes are dragging, which would cause excessive heat.
Did you do this yet? If not, it's hard to rule out any other possibilities. Probably everyone is going to come back with the same response ... check for brake drag.
If you have done this and the wheel spin freely on both sides, and all tires, then there may be something else going on. Let us know your findings.
For example, although a new camper, it could be bad bearings. Any number of things, but we need to rule out brake drag first.
And could be something as simple as the bearing were not packed properly with grease. There are lots of factors.
BB_TX
Were the higher temp ones consistently in the sun during the drive, and the other side consistently in the shade? Makes a difference.
Johno02
I would jack it up and see if the wheels spin free, or about the same on both sides.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
