โSep-27-2015 05:39 PM
โOct-04-2015 03:58 AM
jwmII wrote:
The problem is that as we all get a little older this stuff keeps getting harder to do. In that vein we try to find someone to do this stuff for us and repeatedly get burned in the process. The guy that finds a shop that can meet all of his needs has a real treasure and should count his lucky stars.
โOct-03-2015 08:31 PM
Spridle wrote:
Simple problem actually, Itโs a poor weld with no penetration into the supplied bracket. Itโs clear in the picture.
If there was a design problem causing unwanted stress and I had personally welded the brackets, the shocks would have bent up but the brackets would still be intact.
Another poor MIG welding example. What a crappy bead, it missed the bracket most of the time and attached only to the frame. How obvious.
โOct-03-2015 08:09 PM
time_to_go_now wrote:myredracer wrote:
The whole point of starting this thread was to show how bad a professional suspension shop's welding and work can be and what the consequences could have been, not to argue where shocks should be installed. Done, done, done...
This always happens. The OP starts a thread by "look at what crappy work so-and-so did on my RV". Then they show pictures. The problem is that there are many very experienced people on this site that know how it should have been done. When they start to question the OP, the OP eventually throws out a statement like the one above, "done, done, done".
I build off road vehicles as a hobby. I have a welder in my garage. Used it yesterday to weld some axle brackets together! In a prior life, I made airplane parts for Northrop and Boeing. I have designed many parts, and made many shock mounts. Maybe the issue is just a bad weld. I never would have trusted this to some shop that an RV place wants to use! But, that is just me. The design, IMO, was not a good design. I would have mounted the shocks inboard of the frame. I don't care how much clearance there is outside the frame or who else mounts the shocks outside the frame. I would have made custom brackets that were strong and gusseted that would have just bolted to the frame. Not welded. If that was not possible, I would have created a new cross member that would have gone from frame to frame and welded brackets to that as the upper shock mount.
While your intention was to show how bad a professionals work can be, this thread actually turned in to much more than that. With feedback and opinions from some very smart people. So, while you don't seem to want to listen to any opinion other than your own, I have learned a great deal from this thread. So, thank you for starting it.
Good luck.
โOct-03-2015 06:55 PM
โOct-03-2015 05:35 PM
โOct-03-2015 04:10 PM
โOct-03-2015 01:53 PM
jwmII wrote:
Since you have the tools and expertise to do this yourself it begs the question as to why you didn't do it yourself?? Your specs and drawing probably never reached the folks doing the job.
โOct-03-2015 01:13 PM
โOct-03-2015 07:39 AM
โOct-03-2015 07:36 AM
โOct-02-2015 01:29 PM
โOct-01-2015 04:19 PM
Huntindog wrote:
Nothing wrong with with the Northwood pic, except it doesn't really show how much clearance there is....
โOct-01-2015 03:50 PM
LarryJM wrote:If as you reason they are not needed, then why did my now 11 year old 5er come with them from the factory. Someone up there must have thought they were needed. JMHO.Huntindog wrote:myredracer wrote:.
As well, the installation drawing I made up was sent to Lippert for approval and nothing was asked to be changed.
Now that is funny.
All the drawings that I have sent in didn't get a response indicating that changes were needed either.:B
Lippert or any other big company doesn't respond to every wanna be engineer that sends in proposed mod plans to their products.. Too much liability for them.
Lippert ignored you didn't they? If you even did that.
They are probably still laughing at the office.
I agree ... believing that a manufacturer would respond to such a thing shows a high degree of lack of understanding how things work. While I'm far from what I would call knowledgeable in subjects such as this it seems at least to me clearly demonstrate why one has to be careful in mucking around with some things. Of course I'm also one to strongly question the need for shocks on a non passenger carrying vehicle such as a trailer. I would guess for those few trailers offering such an option it is mainly there for marketing purposes and not for any real "ENGINEERING BASED NEED".
Larry
โOct-01-2015 10:32 AM
Now that is funny.
