โDec-06-2017 05:23 PM
โDec-07-2017 09:20 AM
โDec-07-2017 09:04 AM
Tashajo wrote:
We just bought the camper in July and are dealing with the previous owners neglect. We flushed out the tank and replaced the element. Now to see if it works. It was very badly corroded.
โDec-07-2017 07:35 AM
โDec-07-2017 04:33 AM
โDec-07-2017 04:30 AM
dougrainer wrote:Tashajo wrote:
The water themperature hasn't changed at all. And this would be the third element put in since July if I have to replace it. Im going to drain and flush the tank out and hopefully that fixes it. If not I'll get another new element. Last time it went out it never made a noise just stopped working.
If you have replaced 3 elements in 4 months, you have other problems. Possibly too high voltage to the RV or you do indeed need to flush the water heater tank. Elements will last years, unless you are buying cheap aftermarket elements or elements that are NOT built and the CORRECT length for an RV water Heater. LENGTH maybe your problem. Maybe you have one that is TOO LONG and it is rubbing on the back end of the Tank. Doug
โDec-07-2017 04:26 AM
Tashajo wrote:
Would the check valve make noise when it's heating or just when the water is running? I can run water through and it makes no noise till it starts heating again, then it sounds like an angry coffee pot.
โDec-07-2017 03:50 AM
โDec-07-2017 02:35 AM
โDec-07-2017 12:07 AM
โDec-07-2017 12:02 AM
โDec-06-2017 10:21 PM
โDec-06-2017 08:15 PM
โDec-06-2017 07:57 PM
rhagfo wrote:
Put in by pass and the noise will likely stop,
If it does then the check valve on the hot water outlet port is likely bad, just went through this ourselfs. This is NOT the pressure relief valve, but the brass nipple on the hot water outlet port of the WH.
