What sealant should I use between AC gasket and roof?
deandec
I am installing a Penguin II low profile roof AC unit.
What sealant do you recommend to fasten the gasket to the roof?
Dean
95 CC Magna, Jeep GC
14 REPLIES 14
deandec
Chris Bryant wrote:
The trouble with using a sealant is that the gaskets are expendable- they will need replacing at some point. If the gasket is sealed to the roof, you've added a huge amount of time to the job- getting the roof clean and smooth.
This I learned, but the old gaskets did last 20 years before the refrigerant blew out......
Installed the new AC without sealant although I will not last as long as the old gaskets did.
Dean
Chris_Bryant
-- Chris Bryant
SoundGuy
sjholt wrote:
If it was mine, I would smear a light coat of RTV on the none sticking surface as additional insurance. I did say if it was mine.
It's your rig, you can do anything you want with it but no A/C manufacturer recommends the use of any sealant, just a properly torqued rubber seal affixed to the underside of the top unit. The only "additional insurance" required is periodically checking to make sure those four bolts securing the top unit in place are properly torqued, which I think is the message many in this discussion have been trying to relay to the OP. ๐Ÿ˜‰
2012 Silverado 1500 Crew Cab
sjholt
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
mlts22
X2. If you want to do the job right, grab a clicker torque wrench from Harbor Freight, then find the maker's torque recommendations and use those. Hard to go wrong that way.
dons2346
Old-Biscuit wrote:
NOTHING!!
Clean roof area around opening, Clean A/C Unit pan where old gasket was.
Install new gasket and set A/C Unit.
Tighten the 4 hold down bolts finger tight in cross pattern.
Then slowly 'snug' them up until gasket has been compressed by half (1" thick compressed to 1/2")
DO NOT OVER TIGHTEN.........just hand snug (Can crush gasket, warp roof and/or A/C Pan and cause leaks)
X1
wa8yxm
The Gasket IS the sealant. You do not use any other product. Just the gasket, That is what gaskets do, they seal.
deandec
Thanks for the replies.
I just removed my, at least 13 year old and likely 20 year old, Dometic Penguin AC unit. It was held very solidly to the roof with sealant.
I was surprised and disappointed in the extra two hours required to remove the old AC and clean the residual with a scraper and acetone.
Hence my question. I will put the new one on with no sealant!
Dean
tvman44
No sealant required, just proper torque on bolts.
Papa Bob
Husky 16K hitch, Tekonsha P3,
LarryJM
Golden_HVAC wrote:
I worked on the emergency vehicles at my work with rooftop A/C units that where leaking. The gasket had compressed itself while it was parked, and now the bolts where loose. Like I could turn them 3 turns before they made contact with the inside frame of the A/C/ Then I tightened with a nut driver.
You can use a socket wrench and extension to make it easy for you, but do not "Tighten" beyond finger tight and about 2-3 more turns. Then check it again in a month or so, and snug it down a bit more if required. After 2 years, check it again.
The bolt is probably a 3/8" X 18 threads per inch. So each turn is 1/18" compression on the gasket. 2 turns = about 1/8".
Good luck,
Fred.
Dometic lists an actual torque value when you originally compress the gasket from it's 1" to 1/2" size and that is approximately 40 to 50 inch-lbs so you might use that value to retorque a gasket that is older.
That mumber is from the 6-03 579 installation and operating instructions.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
Golden_HVAC
Good luck,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
DrewE
To the best of my knowledge, gravity is all that is required to attach it to the roof...assisted slightly by the mounting bolts. The gasket is the seal. It would be nice if all the other things that go through the roof were as straightforward to seal properly.
Old-Biscuit
NOTHING!!
azrving
The new gasket will have one side that is peel and stick. It sticks onto the ac unit. At least the 2 that I have worked on were like that.
