What size?
coolmom42
...Is the water heater drain plug? Are they all the same?
There are all manner of packs of these floating around. Like THIS ONE.
Are those angled wrenches of any use? I'm thinking mine is going to need a socket extension to get to it.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
15 REPLIES 15
stevenal
Nomad II
Nomad II
I like to use a 6 pointed socket. Too easy to round the corners off the Attwood nylon plug when using 12 points.
'18 Bigfoot 1500 Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
MitchF150
Yeah, I used a Sharpie and wrote "1-1/16" on it so I know which socket to grab when I want to remove on my Suburban anode/drain plug.
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
Tom_Barb
craig7h wrote:
I have always used the 15/16th socket, with a small extension.
X 2. one socket is best.
skinny, wrenches will slip, and there seems to something in the way.
Old-Biscuit
Clarification:
Suburban Anode Rod Hex head requires 1 1/16" socket
Drain hole is 3/4" NPT
Atwood can be 2 different sizes depending on Vendor
A 15/16" socket OR a 7/8" socket
NYLON drain plug...both are 1/2" NPT
Dusty_R
After I drain our's the first time I replace the plug with a ball valve.
Dusty
fj12ryder
My Suburban also uses a 1 1/16" socket.
Howard and Peggy
"Don't Panic"
RAS43
kellem wrote:
From the 4 trailers I've owned from various manufacturers, 1 1/16" socket has removed the anode to drain.
Same here, all were Suburban heaters.
Lynnmor
Suburban uses a 3/4" NPT anode that uses the 1-1/16" socket. Others use a 1/2" NPT plastic drain plug with the smaller hex.
I might add that the tool maker mentioned in the original post has no clue, photos, descriptions and measurements are incorrect.
kellem
wa8yxm
The Threads are usually 1/2 inch IPT. Atwood normally uses a plastic plug I suggest a six point socket (not a 12) on this plug. Suburan normally uses a metal plug with an anode rod. this one can take any kind of wrench.
page 2: Keep a short length (like 6 to 10 inches) of plastic irrigation pipe, also 1/2 inch thread With water heater cold and pump /city water off. pull plug, thread in pipe open TPR valve to drain (Stand back) pipe takes water out past side of RV. Need not be all that tight. Finger tight will do.
craig7h
Nomad II
Nomad II
Itasca Meridian SE 36g
Road Master Tow Dolly
rockylarson
The wrench that comes with those plugs has two different sizes. I would think that implies there are two different size plugs out there. At least on the outside. The inside diameter of the drain may be the same on all water heaters. I increased the bend angle on that tool and it worked just fine. Channel Lock pliers have worked also.
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
IAMICHABOD
I would try the socket first as I did but it was a no go,So I went with This One and it worked out very well.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Sjm9911
There are diffrent ones, look up the make and model of your heater and match it. I use a short extention on my socket.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
