โOct-18-2023 03:23 PM
โOct-28-2023 05:34 PM
FishOnOne wrote:cummins2014 wrote:FishOnOne wrote:cummins2014 wrote:4x4ord wrote:
There isnโt a hill Iโve been on that I would be afraid to descend pulling a 16000 lb rv with the 7.3 gasser. Low gear and 6000 rpm is a lot of engine braking.
You are a brave lad !!! Can't argue the fact of what a 7.3 gasser will ,or will not do , but I towed a fairly heavy fifth wheel many years with a 7.3 Powerstroke , no EB . Had a few white knuckle experiences coming of some of the hills in Utah, Idaho ,and Montana . Yes learned pretty quickly on how to come down some of those long grades . One example is the one coming from Ennis,MT to Virginia City , MT. It has the runaway ramp if needed .
There's no comparison of the 7.3 Gas with a throttle body, and transmission grade braking compared to a 7.3PSD that has absolutely no grade braking functions.
Bottom line...I'll take a 7.3 Gas over a 7.3PSD anyday for all towing applications.
I will take a 6.7 Cummins over both of them for all tow applications .
So what are your impressions on driving a 7.3 gas truck?
โOct-28-2023 02:00 PM
โOct-28-2023 07:19 AM
โOct-28-2023 07:15 AM
I have no doubt 7.3 gasser will hold back much more than 7.3 diesel with no engine brake. My question is will the Powerstroke, with exhaust brake added, slow any better than the 7.3 gasser.
โOct-28-2023 03:57 AM
Lantley wrote:
All the comparisons are the 7.3 gasser vs. anything but a modern diesel with an exhaust brake.
Compare a 7.3 gasser to the same year diesel that is the relevant equation.
All the other comparisons are antiquated.
โOct-28-2023 03:42 AM
โOct-28-2023 12:10 AM
Yea I know you walked to school in 3 feet of snow in your day.
โฆand you don't need four wheel drive. 2 wheel drive and sand bags got you through the blizzard.
โOct-27-2023 09:39 PM
โOct-27-2023 09:18 PM
โOct-27-2023 03:12 PM
โOct-27-2023 01:53 PM
โOct-27-2023 09:16 AM
Samsonsworld wrote:
Of all the reasons I select a tow engine, exhaust brakes aren't even on the list.
โOct-27-2023 08:50 AM
โOct-27-2023 08:31 AM
โOct-27-2023 08:16 AM
