100,000 mile report
Turtle_n_Peeps
Ok, my 06 LBZ truck just turned 100,000 miles and I want to make a report of the good, the bad, and the ugly. About 25% of those miles were towing.
It always makes me chuckle when people say "I have 20,000 miles on my truck and it's been a great truck."
Well hell, I hope so! It's a brand new truck!
Anyway, here we go.
Engine:
10 oil changes
6 fuel filter changes
2 new glow plugs
2 Air filters
1 set batteries (2)
That's it for the engine.
Other things:
2 sets of tires (factory + 2 sets I put on.)
4 shocks at 50K
4 steering boxes (Don't ask; it did not need any):M
1 set of engine oil cooler hoses.
4 burnt out lights in the steering wheel buttons
1 Steering column bearing
1 intermediate steering shaft
That's pretty much it. Pretty good for 100,000 miles. As far as I'm concerned it won't be a good truck until I get 200,000 with no drive train repairs. Then and only then I will say it is a good truck. 🙂
I really like towing with this truck but don't like driving it solo. All in all, I like my truck. 🙂
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
23 REPLIES 23
wq93
Turtle n Peeps wrote:
You have no idea on how much I wanted to jump over the counter and punch the SW in the face. :M
The good news is a pump from AC is only 150 bucks plus my labor putting it on. Not that big of a deal.
If you are changing the pump make sure to also flush the fluid, you will be amazed at how ugly the old stuff has gotten and you may find that fresh fluid will greatly improve your current steering. See this link and the PDF in it for a method a bunch of us have used. I did my LBZ two years ago and it made a big difference with power steering feel and noise.
http://www.dieselplace.com/forum/63-gm-diesel-engines/140-duramax-third-generation-2006-2007-5-lbz-lly/339919-power-steering-pump-hydro-boost-flush.html
Mortimer_Brewst
DownTheAvenue wrote:
I have to tell you engine oil cooler hoses, steering column bearing, and steering shaft should not fail in 100,000 miles. Not good service.
I agree 100%! GM has been putting bogus hoses on their trucks for over 25 years that I know of. At least it wasn't a head gasket or HPFP! :B
WNYBob: Without writing a book. The steering got hard and weird around 50K (warrantee.) Took it to a dealer and they said it was a box. They put box #1 on. Didn't fix it. I took it back about 6 months later and said fix it. They put box #2 on. Didn't fix it. I told them it was the pump. Box #3 went on. They put the wrong box on. It was clocked about 120 degrees out. I needed my truck so they let my truck go out the door clocked wrong. I told them to stop putting good boxes on my truck and replace the pump. They said "I" didn't know what I was talking about. Grrrrr..........box #4 goes on to fix the clocking issue. Box #4 is still on there to this day. Steering is still not right. I will put a new pump on when I get some time. This will fix the problem for good. 🙂
If the steering isn't right you should check the steering box.
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
transamz9
ib516 wrote:
transamz9 wrote:
2005 Ram 2500 QCSB Cummins 48 Auto 95,000 miles
1. Oil and all filters except air (K&N) changed every spring.
2. Quarter way through second set of tires (Bought only one set).
3. Installed 4 link full air ride under rear.
4. Installed new U-joints front to rear while I was installing 4-link
5. Installed 2.5" level kit under front.
6. Installed new ball joints and u-joints in front axle while installing level kit.
7. Installed 7" touch screen stereo with new speakers and sub with two amps.
8. Washed twice a week and waxed and polished twice a year.:B
9. Installed Bully Dog programmer and MBRP exhaust at around 4 years old.
All fluids are original except oil, rear diff and windshield washer.
No transmission service?
No sir, still factory fluid. I have never touch or had anyone touch the transmission. No band adjustments, nothing. The funny thing is that I have been running the Bully Dog on extreme from day one I put it on the truck. Towing my doubles or not it has been on that setting except when it automatically detunes itself when the H20 gets to the temp I have it set for (220*).
I did forget number 10 though. I have put front rear brake pads on it with new rotors. It didn't need them at the time but when I started towing doubles I put severe duty rotors and brakes all the way around it.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
Turtle_n_Peeps
time2roll wrote:
WNYBob wrote:
"4 steering boxes (Don't ask; it did not need any)"?
You made me ask!
I assume this is poor dealer diagnostics.
Insanity at its' best.
outside the fire"
the_bear_II
The service tech thought something wasn't right with the steering on my 07 4500 when I took it in for the 500 mile service. Supposedly the dealer could not determine what was wrong. A new box was installed still the same problem. So they had an expert from Bosch look at it; still couldn't determine what was wrong. It sounds like the fluid is low (it's not) but the steering works great. 15,000 miles and still the same.
ib516
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
time2roll
You made me ask!
Grit_dog
Navigator
Navigator
And with just a mild tune, that LBZ will run with or bitsch slap every new truck out there.
Hey noticed in your maintenance you don't show any trans filters. A dump n fill with Transynd and keeping up on filter changes is a good move with the Alli.
Campteacher
I like this thread!
2008 Ram 2500 CTD 4x4
81 000 miles (131 000 km)
Oil changes with synthetic twice a year
Axle and transfer case fluid changed every two years
two sets of tires ( I live on a gravel road, it eats them)
Fuel filter changed each year
Transmission serviced once
Bilstein 4600
new front bearings
Mag-hytec transmission pan and rear diff cover
1 pair of new batteries
1 DPF and EGR cleaning done at the dealership
1 brake job
That's all I can think of, it's been good to me.
Kevin
larry_barnhart
gbopp wrote:
A diesel truck with only 100,000 miles? That's almost a brand new truck. :B
That is what I think about our 05 with 94K miles.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
mtofell1
Nice report OP. I loved every mile of my 06 LBZ. I think I put about 125K on it and had nothing huge but a list nonetheless - lots of front end parts, tranny cooler hoses, part of the xfer case.
K_Charles
2004 excursion V10 with 189,??? miles about half towing
Oil and filter about every 8 or 10 thousand
2 air filter,I blow it out when I change the oil
Transmission filter at 110,000
Spark plugs at 120,000
Alternator at about 150,000
Two COP coils around 180,000
Brakes twice on rear three times on front
One spindle bearing and front rotors twice
Rear rotors and parking brake shoes once
Three sets of tires
Replaced battery
Shocks on the front only
One tail light bulb
One tail pipe
I think it has been good to me, but the brakes didn't like the 8500 lb TT (or maybe my driving)
transamz9
Rack maybe?
transamz9
