โApr-10-2022 10:55 PM
โMay-08-2022 10:54 AM
BenK wrote:
Jeremiah
Good thinking and have gotten to know you over the years on this forum, which can say you will do the maintenance well.
There are two things suggest
#1 is that the coolant these days are rated for 5 years or more life cycle. The thermal system is one huge key to the longevity of any of these, modern small displacement ICEโs which are forced fed.
OATs and HOATs coolants are well know to have issues with O2 getting into the system to wreck havoc. The why most all OEMs have gone to a closed, overflow bottle.
They are now pressurized and the main onus is to keep O2 out when folks like me has to check coolant level/condition often. To check is to view coolant level through the translucent bottle walls and that they now have graduations for High and Low. Check on that level at each oil change, or like meโฆcheck it often, along with tires, oil level, etc
#2 is to find and read up on your engine. Did that when Fordโs EcoBoost came out because had similar concerns of the longevity. Found that Ford did many things that were sound engineering. Biggest was that inside the engine, there was/is an oil spray system to cool the piston undersides. That is something boy racers of my day did for their โbuiltโ engines. Meaning that the engine oil is going to see some higher temps than a naturally aspired engine would see.
If you find that info, please post back on this. As Iโve not been able to find itโฆthough havenโt had must time to do a proper search.
Beautiful setup !!!
โApr-14-2022 01:17 AM
mkirsch wrote:Wade44 wrote:Geo*Boy wrote:Lwiddis wrote:
Iโm not convinced youโll be this happy at 80,000 miles. Possibly with the Ford 2.7L but the jury is still out on this Chevy engine. I see BenK is also concerned.
I wouldnโt worry about it, do your maintenance and enjoy your truck.;)
I agree.
I have been convinced 3 times with the Ford 2.7 that somewhere north of 80K, maybe 100K, 120K? miles it develops the common Ford Ecoboost waste gate rattle at cold start, and then eventually upon deceleration, as it continues to wear. Change the oil all you care to. Then its off to buy a new turbo, and a new cat on some of older ones due to a redesign. About $2.5K in parts if you're lucky and have a connection or two. I won't even go into whats involved after doing 3 if you dive into the work yourself, lets just say its a real PITA even with a lift. It would be faster and easier to change the entire engine LOL.
Probably why Ford designed the cab and front clip to lift off in under 2 hours with an experienced mechanic doing the work.
โApr-13-2022 05:17 PM
โApr-13-2022 05:00 PM
โApr-13-2022 06:43 AM
โApr-13-2022 06:20 AM
I agree.
โApr-13-2022 02:17 AM
โApr-12-2022 09:16 PM
โApr-12-2022 06:10 AM
โApr-11-2022 03:28 PM
โApr-11-2022 11:49 AM
โApr-11-2022 11:05 AM
โApr-11-2022 08:32 AM
BurbMan wrote:
215* is a little hotter than I like to see the trans get, although not terrible considering the Dex6 fluid is 100% synthetic now. If it runs hotter in the summer when ambient temps are higher I would consider a supplemental trans cooler.
โApr-11-2022 05:06 AM
