Jul-01-2013 06:38 PM
Jul-04-2013 06:33 PM
Jul-04-2013 06:23 PM
Jul-03-2013 10:46 AM
Jul-03-2013 10:09 AM
Jul-03-2013 10:00 AM
Jul-02-2013 06:14 PM
Jul-02-2013 04:43 PM
Jul-02-2013 04:09 PM
Jul-02-2013 03:26 PM
Copperlisa wrote:
I owe you all a big thanks. You saved me a ton of money, and reassured me to boot. After a session at the car wash this morning (I pulled the shroud and there was enough trash between the radiators that you could have built an eagle's nest!) and a full day of stop and go running around in 100+ heat, the tranny was solid at 165, and the engine at 205. The fan clutch was kicking on and off, because I could feel the difference in the AC in both force and coolness.
So...I'll hang out on the forums for a while and see what else I can learn from y'all. Thanks again!
2005 GMC Sierra 2500HD Ext. Cab 4x4 6.0
1998 Jayco Designer 29RKS
Jul-02-2013 02:57 PM
Jul-02-2013 09:39 AM
Engineer9860 wrote:
You didn't catch this part before you started to gloat did you Ric? :w
Jul-02-2013 07:32 AM
Jul-02-2013 07:23 AM
Jul-02-2013 07:15 AM
Bob/Olallawa wrote:
Can you hear the cooling fan lock in and if so is it locking up for long times or just in and out. Are you slow speed around town or highway speed for good air movement. The temp gauge on these GM's are not the most accurate but unless the fan is staying locked up for a long time I would say you don't have a problem.
