โSep-22-2015 06:04 PM
โSep-24-2015 12:35 PM
Teamfour wrote:
Pads are not worn out. Due to my experience racing cars, I would rather upgrade the pads BEFORE I find out they need changing.
So, can anyone recommend a good pad (thanks APT)?
โSep-24-2015 05:53 AM
Terryallan wrote:brulaz wrote:Terryallan wrote:brulaz wrote:
Just had the brakes on my 2011 inspected, cleaned, lubed and the front rotors turned slightly as I was getting some throbbing when breaking long and hard down mountain grades.
The pads though were still fine at 56K miles. These brakes had been severely over-heated to where you could smell them at least once in the past.
Use the gears to prevent heating the brakes down hill. Use the lowest gear you need to hold it back
Yes, the stinky brakes occurred when I kept it in 2nd. Now I go down that mountain (in your neck of the woods, by the way) in first gear with the engine/tranny screaming at 4000-5000rpm. Don't like it, but it is an EcoBoost with not a lot engine braking.
If these pads ever wear out, maybe I'll switch to something else with more grip but less heat ... if such a thing is physically possible.
I wondered IF the little 6 cly would have much engine braking. I go up, and down those mountains all the time, and the 5.4 holds back the truck, and TT like a champ. I use very little brakes, and never get over 3500 RPM. Fortunately the steepest grades have very low speed limits.
โSep-23-2015 02:14 PM
โSep-23-2015 11:08 AM
โSep-23-2015 10:07 AM
โSep-23-2015 08:58 AM
โSep-23-2015 07:50 AM
โSep-23-2015 06:43 AM
โSep-23-2015 06:36 AM
โSep-23-2015 05:49 AM
โSep-23-2015 04:25 AM
โSep-22-2015 09:50 PM
โSep-22-2015 07:14 PM
Terryallan wrote:
Agree with coolbreeze01. Did you check the pads, or just decide to change them? Towing shouldn't wear the pads any more than non towing, unless you ride the brakes, or don't have the brake controller set correctly.
โSep-22-2015 06:25 PM
