โJul-29-2013 11:08 AM
โAug-08-2013 01:06 PM
โAug-05-2013 05:25 PM
12puma4us wrote:
Just gonna put my input on this topic since I actually own one of these trucks. There is no paperwork that was signed or needed to be signed about any maintenance on the engine. The owners manual does state basic maintenance that should be done just like every other manual I have gotten with a vehicle. As far as the filter needing to be drained at what ever milage, this will more then likely depend on the quality of fuel used.
In my opinion this is a much better engine then the 6.0
I don't dislike chevy nor dodge this was a better styled truck with all the power we needed.
There is plenty of good info about this engine out in the web Joediesel on youtube is a great source watch his videos.
Test drive the trucks if you are really serious wait till all the engines are out and test drive them all and then make a decision.
โAug-04-2013 11:45 AM
โJul-31-2013 09:35 PM
Huntindog wrote:The Mad Norsky wrote:I read the responses to NHTSA from Ford and GM.
Thanks Huntindog. Correct info is nice to have.
In that case, we may actually have our first forum event of a failed Bosch CP 4.2 in a Duramax.
Some avid readers may recall a long thread in the Fifth Wheel part of the forum about a user having truck problems near St George Utah. He was mostly concerned with moving the fifth wheel to a proper location, and the truck was barely even mentioned.
However, out of curiosity I PM'ed this member. He replied back to me his vehicle was a 2011 Duramax and the HPFP had gone bad on it during his trip.
So possibility surely exists it was the CP 4.2. And it was on a Duramax.
VW has been under investigation by the NHTSA for failures of the Bosch CP 4.1 pump in their diesels. Ford and GM I believe both got requests from NHTSA for information about their use of the CP 4.2 pumps.
At least the summary version. There is more detailed info that one can get, but when I tried, my computer wouldn't open it.
So from the summary, Both Ford and GM has had failures. GMs rate is said to be higher than Fords, but I "think" that may be only warrantied repairs. Since Ford has been known to not honor the warranty, they should show a lower failure rate than GM which has a much better reputation in this regard....In fact when I last looked into it, there was not a single case on any forum about GM not honoring the warranty.. Ford had several. Not sure if that is still the case or not.as I don't visit all the forums so much anymore. Just the Dieselplace every now and then.
At any rate, I never said a thing on this thread about Fords use of the 4.2 HPFP. GM uses it too, so I don't see much of a difference between the two in this regard.
In the emissions area, the two chose different paths. I think the GMs approach is the better one, but I can see why Ford might want to go the way they did. This is all new to the big 3. Heck up until now, Dodge was still stuck doing it the old way, (no urea) Which both Ford and GM gave up on in 2011.
What probably troubles me the most is the radiator situation. Ford has had trouble with them now since at least 2008.
What gives? It's not like Ford had to reinvent the wheel. It's a radiator. Millions of cars are produced every year with an acceptable (very low) failure rate. But on the Ford forums a common post starts off as "Well it's my turn"
โJul-31-2013 07:54 PM
โJul-31-2013 07:16 PM
Grit dog wrote:
Ford also has some maintainence requirements that the other two do not..
Antifreeze needs to be tested often using the proper kit.. There is more than one available, and even the dealers sometimes get it wrong. This actually has a message that pops up on the DIC.
The fuel filter needs to drained IIRC every 3 weeks
Ford STRONGLY recommends in writing that you use their PM 22 fuel additive religiously. Some have even had to sign a paper about this on delivery.
And Ford seems to have forgotten how to make a radiator that doesn't leak. And they are VERY proud of the replacements that they sell. Which still leak.
โJul-31-2013 06:37 PM
โJul-31-2013 02:40 PM
My issue was not in your message...it is in your egotistic message delivery.
โJul-31-2013 12:46 PM
Turtle n Peeps wrote:RedRocket204 wrote:Turtle n Peeps wrote:The fuel quality (lubricity) in the USA is the reason I'm running PM-22A. And since the pump is used by other manufacturers besides Ford, I would advise everyone to use some sort of additive that adds lubricity. We all use the same fuel. And notice that the pump is not only used by Ford !
Since you use PM-22A and recommend everybody "use some sort of additive that adds lubricity," do you know what exactly is in PM-22A that adds lubricity?
You've played this game before with your one-up-manship on those who use the PM22A. You could just say it but you have your ego to flex.
Kerosene - https://www.fcsdchemicalsandlubricants.com/main/msds/us178699us.pdf
Hmmm... http://forums.snowgoer.com/Index.cfm/fuseaction/thread/tid/25990894/page/2.cfm
I don't believe I quoted you Red but since you jumped in, my question will work just as good for you:
So a few ounces of kerosene in a 20 or 30 gallon tank lubes your HPFP pump better? :h Alllll righteeeeeeee than, LOL, whatever you say. :R
Any studies to back this up?
If you believe that kerosene lubes, (and we know all PM-22 from the MSDS, is a few ounces of kerosene and a few micro ounces of strong solvent) how does that work when kerosene is a "dryer" fuel than #2 diesel?
โJul-31-2013 12:43 PM
โJul-31-2013 12:34 PM
The Mad Norsky wrote:The Dmax started using the CP4.2 in MY 2011. So I have the GM version of the pump. Not at all sure if they are identical. Bosch says that it is a platform, and they will build to whatever is spec'ed by the manufacturer. But for the time being I am going to assume that the internals are the same, and just mounting bosses etc are different.
Huntindog:
I was busy posting, and did not see your recent post until I was finished.
A question for you. Since your vehicle is a 2011 Duramax, I must assume it does NOT have the problematic Bosch CP 4.2 pump.
It is my understanding that Duramax didn't get this pump until the 2012 model year.
Am I correct or misinformed here?????
โJul-31-2013 12:27 PM
โJul-31-2013 11:36 AM
โJul-31-2013 11:27 AM
