Jan-29-2015 07:10 PM
Feb-03-2015 06:42 PM
We'retheRussos wrote:Home Skillet wrote:
You use premium fuel for max horsepower.
With the lower octane fuel, the power is reduced.
Incorrect. The Octane level determines the amount of pressure the fuel can withstand before it detonates. Higher performance / turbo charged engines like the EcoBoost have high compression ratios and therefore require a high octane fuel to prevent knocking. Using a low octane fuel can cause knocking and possibly damage to the engine.
On engines that require 87, they have lower compression ratios and therefore its not beneficial to put in a higher Octane. People read "Premium" and go for the marketing when it does absolutely nothing - if anything there are tests that show your MPG will go down slightly by using a higher octane fuel than recommended because your engine is not able to ignite the fuel at the opportune time.
Feb-03-2015 06:32 PM
Feb-03-2015 06:03 PM
Feb-03-2015 05:35 PM
The 6.2 always had power to spare to accelerate on demand. There were several places the ECO was not able to accelerate.
Larry wrote:
This thing is flying up the hill.
Curley wrote:
It doesn't feel like it's straining at all.
Larry wrote:
I feel like if I were to floor this thing right now it would just fly up this mountain. It's not struggling at all.
Feb-03-2015 05:22 PM
Turtle n Peeps wrote:In summer it may have been different, but in this test the 6.2 was not waxed, as it had power to spare when the EB didn't.
Where did you get this data? I might have missed it but the only way to know if either vehicle had power to spare is look at the TPS data for the whole run. I have no idea where Moe's foot was at any given time in the run.
If you just going off of the comments of Curley, Moe or Larry let me just post one of the completely wrong comments "Larry" made on this "test": :B
7:18 I never knew GM's 6.2 was a BBC. :S And here I thought GM stop putting BBC in trucks years ago. :R
BTW there is a reason pilots love TC'ers on their engines. They can maintain the same power at altitude that they get at sea level. (at least most of it anyway)
Reading about turbo's and altitude.
As far as the WG setting. On this vehicle I have no idea but with the 360HP F150 they are set just slightly under one atmosphere or 14.7.
More HP usually means more boost but not all the time. My guess is that this engine is running around 15 to 16 PSI of boost. That would put it about 1 liter bigger than the 6.2.
Feb-03-2015 05:07 PM
Feb-03-2015 04:41 PM
RCMAN46 wrote:
I am sure the Eco had gears left.
FishOnOne wrote:
The EcoBoost waxed the 6.2 V8 because of the altitude of the test. Dyno test's performed in Denver on a NA V8 shows how bad HP is affected.
Feb-03-2015 04:39 PM
The Lincoln waxed the GM on the Ike whether anybody wants to admit it or not.
Here is the math to show how this works out.
The GMC comes with a 420 HP NA engine. The standard formula for altitude lose is 3%/ 1000 feet. The Ike tunnel is 11,000 up. I don't know what the climb is from A to B is but lets just say it's an average of 10,000 for round figures. The math says the 6.2 WILL lose over 120 HP at that altitude! That brings the potent 6.2 down to an impotent 300 HP. That's why the Cheby was shifting over and over and over again. It was trying to keep the engine in the power band because it needed all of that 300 HP it had.
Now for the twin snail engine.
The EB is reported to put out 380 HP in this vehicle. Since most turbo engines have extra air to put out they lose very little HP if any. So as anybody can see, the EB is going to have a 80+ HP advantage.
Another advantage is this engine can pump a lot of air at a low RPM giving it a wide flat curve.
Another thing to think about is the weather. The 6.2 would have a very hard time pulling up that mountain if it was 90 degrees out. Air density would have been way down. The GMC really got an advantage when towing in this type of weather.
Feb-03-2015 12:02 PM
Feb-03-2015 11:27 AM
Feb-03-2015 08:45 AM
Feb-03-2015 07:57 AM
In a non-direct injected engine, the above theory is correct. Not sure the same applies to DI engines. That is the reason DI exists. Check out the compression ratio on a Mazda Skyactiv engine. 13:1 on 87 octane, because it has DI.
Feb-03-2015 07:02 AM
Feb-03-2015 06:44 AM
RCMAN46 wrote:rjstractor wrote:
It should be noted that the two engines were not rated at the same horsepower, IIRC the 6.2 has 420 and the Eco has 380. It seems as though they were pretty evenly matched although the 6.2 with the 8 speed seemed to be constantly shifting. That would make me crazy.
That is the whole idea behind the 8 speed and there is a 10 speed out there.
A transmission that has many close ratios will allow more gear shifting to keep the engine rpm in it's max power range. Also allows the use of tall rear end ratios which will give better economy at light loads.
Possibly one reason the GM did better on fuel.
If you do not want gear changing we can go back to the old 3 speed transmissions of the 60's and 70's.
Feb-03-2015 02:08 AM
