โMar-23-2016 06:07 AM
โMar-24-2016 09:01 AM
โMar-24-2016 07:27 AM
tinner12002 wrote:transferred wrote:Cummins12V98 wrote:
The comment about the 3500 with Aisin constantly "HUNTING" and 3.42's not being good gearing.
If the truck is placed in TowHaul it won't hunt. Aisin makes the 3.42's work within it's GVWR because of the lower starting gears. When towing lock the trans in 5th it will be exactly the same RPM's as if it were in 6th with 4.10's.
Bonus is better economy running solo with 3.42's.
I towed 28-29K combined with 3,42's and only negative was starting on a grade. That would have been cured if I had the Aisin instead of 68RFE.
This post is spot on. I have 342s in my 2016 in sig and it pulls v strong, I've towed at 24k GCWR across three states and on job sites have gotten trailer with a small-medium 'dozer on it moving with no issue.
I bet it would be easier on your truck and drivetrain when taking off if you had lower gears...and I also bet there's not much difference at all in fuel economy running solo.
โMar-24-2016 04:04 AM
โMar-23-2016 08:37 PM
โMar-23-2016 08:11 PM
โMar-23-2016 07:45 PM
โMar-23-2016 06:56 PM
โMar-23-2016 05:41 PM
GBuilders wrote:
Are you sure you can't get 3.73 on the 3500 srw's? I have 3.73 on my DRW Megacab.
The one thing GM needs to do is offer a larger crew cab option. I had the 4 door 2500 HD but it's not as comfortable in the rear as the Ford and especially the megacab with a family traveling or your buddy's on a hunting trip.
โMar-23-2016 04:38 PM
โMar-23-2016 04:28 PM
โMar-23-2016 04:04 PM
โMar-23-2016 03:31 PM
โMar-23-2016 01:48 PM
Cummins12V98 wrote:
NC tell us how you really feel.
โMar-23-2016 01:36 PM
