โOct-19-2016 04:50 PM
โNov-28-2016 03:50 PM
โNov-28-2016 03:31 PM
โNov-28-2016 03:18 PM
โNov-28-2016 02:04 PM
โOct-21-2016 12:20 PM
โOct-21-2016 11:43 AM
โOct-21-2016 10:51 AM
zb39 wrote:GeoBoy wrote:Bedlam wrote:
Contact Randall at Host for an option sheet with MSRP prices. We are getting 3x160w solar, Fantastic Fan instead of Heki, Full wall cab over wardrobe, Prewire only for TV's and some additional modifications to the umbilical connections.
No one other than Lance is using cab over struts - I'm not sure any of the structures from other manufacturers were designed for an underside load. The Host camper height is 9.5' if you include the AC - Do you want store or carry items up that high on the roof? Rearview camera is a $900 MSRP option.
Your F350 will be over GVWR and close to rear axle capacity with the Mammoth. If you also plan to tow behind your setup, you need a bigger truck. I suggest skipping the F450/4500 and going to a F550/5500.
Randal can say what he wants, Bedlam has researched this camper thoroughly and when he tells you that a 550/5500 is what you need to carry this camper safety and comfortably you should listen to him and not your pocketbook.
No offense but Bedlam can say what he wants. I will listen to the guy that works at the factory. Maybe Bedlams does weigh 6k. But everybody packs differently and gets diff options. Either way I didn't expect this kind of anger and hostility, I have better things to do and I wouldn't want to be responsible for someone getting upset and having a stroke.
โOct-21-2016 10:05 AM
Fastbrit wrote:
Bedlam
With your 5500 flat bed and the host mammoth you will be almost 14 feet high?:h
On the mammoth the a/c is duct in the ceiling?
My set up is 13,4' total
camper is 119" tall from bed to a/c
โOct-21-2016 08:51 AM
โOct-21-2016 03:58 AM
โOct-21-2016 03:29 AM
zb39 wrote:
According to Randell at the factory the weight sticker is VERY close to what the unit weighs. Notice I said there is a base weight and then a weight for the unit as it is equipped. IE all options. I also said it is a dry weight. Not wet and loaded. Everyone is different in that aspect of RVing. If I buy one I will weigh it several times to see how it comes out.
Every unit has the weight sticker. It's by the door. It shows base wight and what the unit weighs with the options on that unit. Again Randell told me most are leaving the factory at 4300 to 4750. The 3 I looked at were all in that range. All had 3 slide outs and 2 had the gen set.
โOct-20-2016 07:33 PM
โOct-20-2016 07:20 PM
โOct-20-2016 06:54 PM
