โDec-27-2013 04:49 PM
โJan-03-2014 11:33 PM
โJan-01-2014 02:03 PM
โJan-01-2014 12:55 PM
wnjj wrote:Paul Clancy wrote:wnjj wrote:Redsky wrote:
I used to have to get out of my truck and engage the manual hubs and get back into the truck and start down the road again and then do the same when back on dry pavement.
You can leave the hubs in on dry pavement or all year for that matter. It just costs you mileage. In the old days, some people left them in for the winter if they frequently needed 4WD.
Except if you do that you will bind or skid when turning corners on dry. Can't imagine that is good for the transfer case and front diff. Are we still talking about 4wd?
You can leave the hubs in with the transfer case in 2WD. The front axles and drive shaft will be spinning at a different speed than the rear at times but aren't connected to the rear when in 2WD. I was addressing the comment about having to get in and out to switch between 2WD and 4WD.
โJan-01-2014 12:02 PM
Terryallan wrote:
All wheel drive. Is usually only 2 wheels engaged at a time. One on the front, and one on the back. Should one, or both of those wheels slip. they are instantly disengaged, and the other two are engaged. Should those slip as well. The system tries to engage the other two again. And if that don't work. The system "CAN" disengage all four.
โJan-01-2014 10:43 AM
โDec-31-2013 07:11 AM
โDec-31-2013 05:56 AM
wilber1 wrote:
How much do you want to spend? The Audi Q7 TDI has a 6500 lb tow rating with the tow package and full time AWD.
โDec-31-2013 05:31 AM
โDec-30-2013 07:44 PM
โDec-30-2013 07:08 PM
โDec-30-2013 05:06 PM
โDec-28-2013 02:16 PM
Terryallan wrote:
Thing is. there is a HUGE difference between real 4 wheel drive, and All wheel drive.
4 wheel drive is when all 4 wheels have power to them. And so when you turn a true 4x4. The difference in wheel speed from the inside to the outside. Binds the axle, unless one tire can slip. Needing a slippery surface to slip on. OR the trany is burned to a crisp.
All wheel drive. Is usually only 2 wheels engaged at a time. One on the front, and one on the back. Should one, or both of those wheels slip. they are instantly disengaged, and the other two are engaged. Should those slip as well. The system tries to engage the other two again. And if that don't work. The system "CAN" disengage all four. No damage done. But the vehicle won't move.
So If you are never going off road / pavement. All wheel drive is usually good enough. But in heavy snow, mud, or sand. Real 4x4 is a must.
โDec-28-2013 01:34 PM
Francesca Knowles wrote:ScottG wrote:
All of those trucks can be put into 4WD on the fly, any time you wan't. So that's really not a factor.
Scott, Scott...you've missed the point!
O.P. wants something that can be driven in 4 wheel drive in any conditions, on dry pavement, at any speed for prolonged periods of time, yadda yadda yadda.
But only when he SHIFTS IT into 4 wheel drive. Because he doesn't want all-wheel drive, no, sir. Sometimes he wants it to be in two wheel drive so he can shift it into 4 wheel drive. On dry pavement. At any speed. Regardless of conditions/necessity etc.
Are you up to speed now? ๐
โDec-28-2013 12:49 PM
