โMar-30-2019 06:51 AM
โApr-01-2019 06:11 AM
SweetLou wrote:
Has any one considered recalls on ea brand or the maintenance costs for EGR or other servicing? It would play into my decisions, but at the end of the day, a lot goes into buying a new truck not just what they can out pull or if they get off the line quicker. That one still amazes me why they think racing an almost 8000 lb truck is even relevant.
โApr-01-2019 05:51 AM
โApr-01-2019 05:38 AM
โMar-31-2019 11:43 PM
โMar-31-2019 08:23 PM
Cummins12V98 wrote:
Here is another thing to consider. What does CUMMINS do??? They build engines!
They sell the 6.7 to RAM but they also sell the same engine to others for Medium Duty applications. "True medium duty"
GM's D Max is used by what other Medium Duty Manufacturers? "Crickets"
Same goes for the Medium Duty AISIN transmission as it's used in many other MD applications.
"ALLISON" (GM Built), who else uses that trans for MD applications? "Crickets"
Well let's add another thing to chew on. Simply look around out on the Highways. What brand DOMINATES the "Independently Owned" RV and HotShot hauling market. RAM, there is simply no comparison.
Oh, they use them a lot to haul Fords. ๐
โMar-31-2019 02:34 PM
Groover wrote:Grit dog wrote:SidecarFlip wrote:
I like them all so long as they smoke....
I'll drink to that! Roll coal brotha!
I sincerely hope that you too are joking. I was raised that when something I do offends others I needed to reconsider my ways, especially if that is the only reason for doing it.
โMar-31-2019 02:11 PM
Turtle n Peeps wrote:RCMAN46 wrote:
"They also operate at lower engine rpms, which lowers the piston speed. Pretty much an irrelevant negative on the I-6!"
If you are comparing the Cummins with the Duramax then you are dead wrong.
Here are the facts.
The Cummins makes its peak torque at 1800 rpm
The Duramax makes its peak torque at 1600 rpm
The Cummins makes its max horsepower at 2800 rpm.
The Duramax makes its max horsepower at 2800 rpm.
So much for the popular belief that the I6 Cummins operates at a lower rpm than the v8 Duramax.
So the statement that the Cummins operates at a higher piston speed holds true when comparing to the Duramax.
So refreshing that someone gets it! ๐
โMar-31-2019 02:00 PM
Here are the facts.
โMar-31-2019 01:49 PM
โMar-31-2019 12:33 PM
โMar-31-2019 11:52 AM
mtofell1 wrote:
I do keep an eye on the diesel trucks and well may end up with one again someday. I lean Ram mainly because that's what I've been driving and am generally happy with it. Also, for whatever reason, I think you get a lot more truck for the same money with Ram. Chevy/GMC would be next. Ford must be packing diamonds in the fender wells for what their trucks cost.
All 3 brands are great so you really can't go wrong. Research is key so you are doing it right, OP.
โMar-31-2019 10:10 AM
โMar-31-2019 10:07 AM
โMar-31-2019 09:59 AM
