Jun-24-2018 06:25 AM
Jun-26-2018 09:27 AM
monkey44 wrote:
HAHAHA == pretty soon we'll be spending all our time in the shifting mode, and no time in the driving mode. Can't wait for the announcement:
Ladies and Gentlemen, start your engines - we now have a twenty-speed Allison for your shifting pleasure.
Jun-26-2018 09:19 AM
Me Again wrote:I agree. All the improvements are a step closer to going electric.
Maybe Diesel/Electric will take over like Locomotives and Ships!
Jun-26-2018 09:00 AM
Me Again wrote:
Rebuilding a 47RE cost around 3-4K. Rebuilding a 6 speed 68RFE cost 7-8K. Not sure on Aisin, as I have not heard of a rebuild. Rebuilding a 6R140 or Allsion 1000 6 speed are similar in the 7-8K range.
Image what a 10 speed will cost to rebuild!!!!
Jun-26-2018 08:18 AM
parker.rowe wrote:
If they can make a 10 speed transmission with the required torque rating, I'm not sure why you would argue that you want less ratios to choose from for varying grade hills, headwinds, hauling weights, etc.
EDIT: Based on current 10 speeds, I would guess max overdrive will stay the same for the most part. But you will have less gear spread and much lower low gears without big gaps between them.
Just because you don't NEED it now, doesn't mean it isn't better.
I think its a great idea, gas or deisel.
Jun-26-2018 08:14 AM
Jun-26-2018 07:55 AM
Jun-26-2018 07:14 AM
Jun-26-2018 06:12 AM
Ralph Cramden wrote:
The end ratio of high gear is going to be in the neighborhood of 0.68/1 no matter if it's a 6 speed or a 20 speed. Assuming we're talking HD gassers, which hit their powerband at a high rpm, other than squeezing an almost impossible to notice MPG gain the extra gears don't give you all that much.
Now in a truck that's used by Joe Schmow to haul a couple of bags of mulch between work commutes, or Soccer Sally to haul home the groceries, which are what the vast majority of light duty trucks are used for it makes all the sense in the world to have some extra ranges between top and bottom. In a HD truck being used as an HD truck it does not make as much sense. I suspect I am getting an 8 or 10 speed through no choice of my own the next time I buy a truck, but my current 2015 GMC 2500 with its 6 speed has more than enough intermediate gears, I don't know what I would be gaining with 2 or 4 more other than more heat from more shifts and additional parts to wear or fail internally. I was not looking for mileage when I bought it.
Jun-26-2018 06:03 AM
Basically that is the Volt, except it isn't diesel and it has a battery pack to store energy.
Jun-26-2018 05:43 AM
Me Again wrote:valhalla360 wrote:
And the old guys probably said the same thing when automatics went from 2 to 3 gears.
CVT's used in trucks will be nothing like the snowmobile transmissions. Of course they aren't going to use a simple rubber belt for a truck towing 15k lbs. That's also why they haven't put the trucks out with CVT's yet but I can guarantee someone is working on it.
PS: Just looked up and there is a consortium of semi tractor manufacturers working on one.
OK, so in 1976 to 1979 I drove a truck with a 13 speed Roadranger tranny. Along came people have did not know how to drive a manual tranny, so Firetrucks and garbage trucks got automatics. The CVT trannies will complete the circle. BTW, I really liked the 13 speed, let the clutch out in the tank yard in Port Angeles and put it back in at Forks 70 miles away! With lots of shift in between.
Chris
Jun-26-2018 04:59 AM
Jun-26-2018 02:19 AM
Jun-25-2018 09:50 PM
Jun-25-2018 08:24 PM
Jun-25-2018 07:15 PM
