Adding ac but keeping fantastic fan
sasq40
So I'm wanting to add ac to our 04 okagaon 811sl. It looks like it's prewired, there's a yellow 110 cable behind the power box not attached to anything. The problem I'm having tho is we do lots of camping that doesn't have shore power so I'd like to be able to keep the fantastic fan for those times. We also tour around sometimes and leave the dogs in the camper so I need it to keep them cool in there. Any tips on how to proceed are awesome.
Also on a side not I'm not afraid of cutting or wiring anything. I've already rebuilt the front overhang wall and I used to be in construction and I've wired my basement so neither of those areas I'm shy of doing.
7 REPLIES 7
mkirsch
Nomad II
Nomad II
The fantastic fan in the bathroom will move air just as well as anywhere else in the camper, as long as the door is open.
My concern with cutting a new hole is, where do you cut it so as to not compromise the framework? It would be awful to start cutting, only to encounter a roof support and not be able to adjust the hole's location because of an interior feature such as a partition wall or cabinet.
EfonFred
We have A/C and the fantastic fan. Our fan is also located at the rear of the camper by the door. Believe me, crack open a few windows up front and that fan moves air. Honestly, because of how effective the fan is we don't use the A/C very often. I'm guessing it wouldn't make much difference between it being placed in the bathroom or elsewhere.
2011 Ram 3500 Mega DRW
2015 Adventurer 86SBS
Reddog1
Old-Biscuit wrote:
Do you have a fan in bathroom?
Swap it with the Fantastic and then install the A/C where Fantastic was.....provided AC power is available up there.
14" X 14" opening needed for either fan or A/C
This is what I did, but I used a Surflo fan. I installed a MaxxAir cover over over my Surflo fan. I seldom close the MaxxAir vent, it does not รคllow rain or wind in the TC. If I want fresh air in the TC, I slightly open windows and pull air through the TC, allowing for complete circulation. If I really need to vent the bathroom, blow air out with fan on high.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
AnEv942
When I replaced Fan-Tastic Vent with AC I cut in new hole to reinstall the F/T.
We do have a rear vent by back door but centered in camper seemed optimum for air control
- but really it was for the light it gives that we wanted it to stay middle of camper.
My older thread of install, second post actually cutting in for new vent.
If AC out and you can place F/T near would allow extending the 12v for future retrieval near to where hole will be added.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
Buzzcut1
Nomad II
Nomad II
I have the AC midships and the Fantastic Fan to its rear by the door. It draws air in from the Cabover hatch cooling the rig just fine for the dogs. if I need more airflow I open the bathroom vent and turn on it's fan
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
sasq40
Yeah we have one in the bathroom, would that be adequate cooling the whole camper? Thinking maybe cutting hole in above kitchen and fishing wires and sticking the fantastic there.
Old-Biscuit
