Adding Better Reverse Lights on a Camper
thundercloud
Has anyone every installed a set of reverse lights on their camper. I was thinking of adding some powerful LED lights from Rigid Industries or Black Oak LED. Wiring them in will be the biggest task. Any suggestions?
Happy TC'N,
David
____________________________________________
2006 Dodge Ram 3500 MegaCab 4x4 CTD 6-speed
2008 Bigfoot 25C9.4SB, Xantrex XADC 60, AM Solar 200 watt SunRunner system, Mach8 Cub, Honda eu2200i, Rigid Industries LED lights
32 REPLIES 32
towpro
search amazon for 12V wireless remote switch. you will see many. I would recommend "RF" because that will transmit through walls. With this switch you can wire lights to camper battery, than switch them on from inside truck cab with switch. Plus you can take switch in camper with you and be able to turn them on from within camper as "scare lights". if you have to worry about DOT (or inspection like in PA) just leave the switch inside the camper.
What I did to my 2015 Ram, and will probably repeat on my 2018 is mount LED fog lights under the body of truck back behind the rear wheels. I can turn these on from the cab and they light up the side so I can see the Jersey barriers (concrete walls in construction sites). but don't shine out past maybe 6-8 feet. since they are low enough and under the truck cars around you can't see them. The jeep crowd calls them Rock Lights (but I used fog lights).
This also works well in campground because you can see the blocks you are backing onto in the dark but you don't light up the whole campground.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
mkirsch
Nomad II
Nomad II
The reverse lights in the taillight housings are what count for the DOT. Anything else is "auxiliary lighting."
I just love all the big talk about telling the DOT where they can go, when they know they're legal all along...
thundercloud
I agree with you AnEv942 that the factory Bargman lights 5 feet of the ground are not worth anything but to warn people behind you that you are backing up. So I am looking at doing something very similar to what you did just using LED lights that use less amps and put out brighter light. Thanks for the photos.
Happy TC'N,
David
AnEv942
thundercloud wrote:
So the plan is to mount the lights to the camper itself. Having said that the only thing that I will have to disconnect would be the umbilical cord that I am currently using to connect/disconnect the truck to the camper (7 pin plug). Is this possible to wire everything to the camper and activate the new reverse lights when the truck goes in reverse?
Yes as you outlined prior if wanting to relay. Cant say 20 watts warrants a relay though.
I just use inexpensive sealed beam flood work lights in rubber housing mounted under bumper.
The factory Bargman backup 'indicator' lights 5' off the ground are pretty much useless.
I think they are 27 watts each (~2amps).
To wire I can access the left taillight wires thru an exterior cabinet.
Just dropped a lead to back of bumper, branches to feed both tractor lights.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
thundercloud
GordonThree wrote:
thundercloud wrote:
So if I go larger then the 20 watts do I wire directly to the camper batteries with a relay and tap into a reverse light that is already on the camper to activate the new backup lights?
Wire a relay into the truck's 12v system, unless you're mounting the lights on the camper itself. The objective is to not have to disconnect a bunch of stuff if you separate the two.
Happy TC'N,
David
ScottG
GordonThree wrote:
Don't tell the DOT, but my lights are manually switched. I like to see behind the trailer, even if my trans is in park or drive, for purposes of lining up in a site for example.
Same here and I couldn't possibly care less what any DOT says.
GordonThree
thundercloud
Happy TC'N,
David
wnjj
skipro3 wrote:
My 2012 Lance camper comes with rear flood lights controlled with a rocker switch just inside the door. I discovered they also turn on when I put my truck in reverse!
So much for DOT and reverse lights not allowed to be manually switched....
They DOT rule may be that they canโ€™t be switched from the drivers seat to prevent โ€œflashingโ€ the guy behind you but I donโ€™t know for sure. They may also want to be sure itโ€™s not left on by accident in which case any switch would count.
Since the camper is cargo, maybe the same rules donโ€™t apply?
thundercloud
That's way cool. Kinda the best of both worlds. Did those come come stock with your camper?
Happy TC'N,
David
GordonThree
Ski_Pro_3
RoyB
In our state the REVERSE LIGHTS comes under the DOT SAFETY LIGHTS purview meaning they have to be DOT APPROVED. The lenses are required to have DOT ID numbers and of course I'm sure there is spec on how bright they might be. They also have to be wired in to operate from you going into REVERSE and not be wired to an individual ON-OFF switch.
I got around all of of this by mounting my back of the trailer lights to rear sides of the trailer. I can't see directly behind my trailer anyway so having side lights worked out just as good...
Not sure if your state has any problems with your planned install or not. Just passing along my licensed state would do...
Some guys have done rear trailer lights mods only to have to remove them to pass their required SAFETY INSPECTION... Checking with your local DMV/DOT would probably be a good idea before dumping monies into your project...
My 5th wheel has the 8-inch scare light mounted high on the side of my trailer which is no problem here in this state. This has a separate ON-OFF switch on the inside trailer wall.
Google image
My off-road Starcraft RT14 popup trailer has a single 8-inch scare light mounted on the front of the trailer to be used with the front deck and this has not been any problem. It has a separate ON-OFF switch on the inside wall.
Google image
Mounting brighter REVERSE LIGHTS under my RT14 trailer rear bumper had to be removed because they did not have DOT approved lens and also did not come ON when going into reverse from my truck...
Rear lights looked like these
Google image
Just passing on a couple of my experiences dealing with DMV/DOT inspections...
Roy ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Kevinwa
I have intended to do this with my car hauler trailer. I have also thought about on the camper. I feel, but donโ€™t know because I havenโ€™t tried, that it would be beneficial to mount them near the front, or half way along the trailer pointing out at a slight angle, so that the side of the trailer can be illuminated as well as the rear. That way you could see where your tires are and where you are steering the trailer
thundercloud
GordonThree wrote:
If you're looking at more than 20 watts of lights, consider using a relay to avoid taxing the existing lighting circuit.
So 20 watts is about the max you could go if you tap into the 7 pin harness? I was thinking of doing that but I was not sure if it would work or not.
Happy TC'N,
David
