May-06-2018 08:45 AM
May-12-2018 06:37 PM
May-12-2018 06:23 AM
Atlee wrote:
With that trailer, and since you haven't bought a truck yet, I highly suggest you go straight to a F250/2500HD truck.
May-11-2018 07:13 PM
rbpru wrote:so let me see if I got this right. Just because your 1/2 ton only has 1411 lbs of payload everyone else most have only 1411 lbs of payload. What if he gets a 1/2 ton with 2000 lbs of payload? By my calculations your 5000 lbs dry weigh is full of sheet.
Well by now the OP should know that a pick up can pull a lot more than it can carry. My 2010 F-150 can pull 9500 lbs. but the max cargo means it can only carry 1411 lbs. And, each vehicle is different depending on the features it left the factory with.
Of my 1411 lbs. of cargo capacity two adults, a big dog, bikes and other toys eat up about 700 lbs. leaving 711 lbs. for the tongue weight.
The hard fact is a half ton pick up is good for about a 5000 lb. dry weight TT, when both are loaded for the road.
I have never found braking to be a issue with properly adjusted TT brakes, even in the Rockies.
May-08-2018 07:52 PM
May-08-2018 07:20 PM
troubledwaters wrote:DallasSteve wrote:But, you can't get the 3.5 Ecoboost and 10 speed transmission in a F250.
...But - by they time you get to that much power you may be near the price of an F-250...
May-08-2018 12:47 PM
bobndot wrote:Bumpyroad wrote:
how do you seat 5 in the rear seat of a pickup?
bumpy
Didn't you see those guys at the Kentucky Derby ?
May-08-2018 11:38 AM
bumpy
May-08-2018 07:56 AM
May-08-2018 07:34 AM
APT wrote:
afidel,
Get off the internet and open truck doors. Dealer lots, auto shows, etc. Locate this sticker for as equipped payload.
Anyway, OP wants Ford or GM. 7000-7500 pounds should be good for the more capable half tons and family RVing. 3/4 ton would be more forgiving on WDH adjustments, but both will be comfortable/safe for driver and passengers. And the half tons will be more comfortable non-towing and use less fuel.
May-08-2018 04:44 AM
May-08-2018 04:04 AM
May-07-2018 05:20 PM
May-07-2018 04:56 PM
May-07-2018 02:25 PM
