โFeb-26-2014 05:36 PM
โFeb-28-2014 05:47 PM
โFeb-28-2014 05:13 PM
โFeb-28-2014 08:11 AM
โFeb-28-2014 07:49 AM
goducks10 wrote:
If you're adding air bags then the proper way to use air bags and a WDH is to load the back of the truck with your camping gear then inflate the bags to restore the rear to it's original hgt.
Then hitch up the TT coupler and use the WDH to restore the front of the truck to near it's original hgt.
โFeb-28-2014 06:19 AM
โFeb-28-2014 05:41 AM
โFeb-28-2014 05:28 AM
โFeb-28-2014 05:00 AM
Ron Gratz wrote:Lynnmor wrote:A trailer with 1000# TW and a correctly adjusted WDH would not add 500# on the front axle. After adjusting the WDH, the net load change on the front axle would be approximately zero, and a load of about 750# would be added to the rear axle.
Just for grins, an example would be a trailer with 1000lbs of tongue weight. You adjust the WDH to put about 500lbs on both the front and rear axle. Add some cargo in the bed. That might put the front down 1/2" and the rear down several inches. Do you really want to drive with the headlights blinding oncoming traffic?
If a trailer-induced load of 750# plus "some cargo" in the bed causes the rear to drop "several inches" the TV's rear axle probably is overloaded.
As APT posted, a properly adjusted WDH might result in a rear-end sag of about 1.5-2". It's very unusual to hear of more than 2" sag with a properly adjusted WDH. From the reports I've read, 1" is more common than 2".
Ron
โFeb-28-2014 04:20 AM
โFeb-27-2014 07:09 PM
โFeb-27-2014 05:04 PM
โFeb-27-2014 02:23 PM
โFeb-27-2014 02:16 PM
Ron Gratz wrote:Lynnmor wrote:Are you saying the rear end should be raised to the unhitched height? If so, why?
If you have soft rear springs then even a correctly adjusted WDH will not raise the truck to where it should be.
Ron
