Am I stretching my ecoboost limits?
WI_Bowhunter
I am considering purchasing a new travel trailer soon. Was wondering what you guys think about tow vehicle to trailer. I have a 2011 F150 Ecoboost 3.5 with Max Towing, 3.73, 11200 GTWR, 1897 Payload, 17100 GCWR.
The trailer I am considering is a Salem 31QBTS.
Dry Weight 8140
Hitch weight 885
Cargo Cap. 2867(will not load more than 1500 tops including fresh water)
I figure total trailer weight to be around 9500-9700 loaded.
let me know your opinions and experience! Thanks
Keep the Shiny Side Up!;)
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
34 REPLIES 34
CND_SuperCrew
jerem0621 wrote:
Anybody know where the payload would be with a supercrew lariat 6.5 bed max to and HD payload?
My dealer said he couldn't locate the HD payload package with this configuration.....????
Look on your driver door or post, there where be a white sticker showing all the codes then there is a yellow sticker that shows tires, cargo front and rear axle weights. What you are looking for is the last number that will show payload. For HD pkg you should see a # close to 2200lbs or there aboutsโ€ฆ
TV 2012 F150 loaded XLT EB SuperCrew 7700GVWR Maxtow 6.5'
TT 2021 Keystone Passport GT 2870RL
modern_family
Is this chart what you are looking for?
2017.. Prime Time Avenger. 32QBI
His.. 2011 F-350, King Ranch, 6.2L. Crew Cab, 4x4, 8' bed, SRW, 11,000 GVWR
Hers..2008 Ford Expedition, King Ranch Heavy Duty Tow, 3.73 gears
Sold.. 2005 Star craft, Travel Star 18SB
Sold.. 2013 Keystone Laredo, 291
jerem0621
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
CND_SuperCrew
Dry Weight 8140
Hitch weight 885
Im sorry but there is no way you have that much payload capacity on a 145" wheelbase. I come in at 1700# with everything you can add for towing minus the HD pkg
APT
The only problem I see is the receiver and payload. The Ecoboost has plenty of power, plenty of wheelbase. But you will likely be over the 1150 pound receiver rating, and it's easy to throw a bunch of stuff in the pickup bed to go over GVWR.
Do you really need the double slide BH? Crew cab truck means 5 people. Are you taking friends? Prime Time Lacrosse 318BHS is my favorite BH, although it is growing in features and weight. Tracer 3150?
2017 Subaru Outback 3.6R
TECMike
Sounds like the tail will probably wag the dog. Think you are probably going to need more truck or less trailer for safety purposes.
AlmostAnOldGuy
I believe your receiver is rated for 11500. With a 9,600 lb trailer you are exceeding your receiver rating even at 12.5% on the hitch. The trailer will also exceed the curb weight weight of your truck by greater than 50%.
I would not tow that much trailer with that TV.
Good luck,
Stu
2012 F150 HD/Max Payload (8200 GVWR, 2176 payload) SuperCrew EcoBoost
2008 Komfort Trailblazer T254S
fla-gypsy
I think it is a stretch on that much trailer
Buck50HD
The eco will handle it but without the HD payload package for added stability, it's too much trailer.
New: 2014 F250 Lariat 6.2 Crew 4x4 3.73 156", 2725 lb payload
Old: 2012 F150 XLT ECO Screw 157" 4x4 3.73LS Max Tow HD Payload, 2171 lb payload
2013 Heartland Sundance XLT 285BH (7750/8800lb, 1400/1700pin, dry/loaded)
Steeljag
Yes,
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
kw_00
X2 on F250 with 6.2
A truck, a camper, a few toys, but most importantly a wonderful family.
EcoBullet
I haven't towed very far with mine yet, so I'm not really an expert, but I think I would try and go lighter. As Skip already said, you are liable to be over on your tongue weight. Unless you've got over 6 people, you might look at something like the Bullet I have. It is a lot lighter and has a fairly similar floorplan. http://www.keystonerv.com/bullet/
Me 1954, Nana 1954, Grandson 2003, Granddaughters 2005 & 2008
2014 Keystone Bullet Premier 22RBPR
2013 F-150 XLT Supercrew 4X4 Ecoboost Max Tow
modern_family
What wheel base? You will be pushed around more than you should. An f250 will haul it that much better and wont keep you guessing about what you can and can't bring with you.
I just saw you wheelbase in your sig.. Almost every car on the road will push you around when they pass.
skipnchar
While you are stretching the limits a bit it all depends on HOW you travel. ON my 8,000 lb. fully loaded trailer by the time I get the truck loaded with cargo and people, I am moving about 10,500 lb. against my 11,300 lb. tow rating. The trucks handles that weight very well but would expect that to at least SOME degree you also would be carrying stuff in your truck while towing. ALL of that weight goes against your rated maximum trailer. I"d also be considering just what the actual tongue weight will be when you're fully loaded because you MAY not have enough receiver capacity to handle it. The EB HD model like mine is delivered with a 1,200 lb. maximum tongue weight and that's just 50 lb. extra for my Rockwood. I would expect that your trailer would be heavier in the tongue than mine (as much as 15% of the GVWR of the trailer.
One thing to consider about the Ecoboost. You will nave almost NO diminished power at high altitude so towing only in flat land should not be an issue. I climb 8% grades in 4th gear adn 1800 RPM up to over 12,000 feet elevation.
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
Lantley
You will be at your limits. I'd say it's doable if you travel on flat terrain. If you do a lot of mountainous travel I would opt for something else.
Since you already have the truck you could give it a whirl as long as you understand and are prepared to upgrade the truck if the first few trips do not go well.
Does it makes sense to buy a rig that puts the TV totally at its limits?
