โMar-16-2016 05:57 AM
โMar-20-2016 08:52 AM
โMar-20-2016 06:05 AM
โMar-17-2016 04:35 AM
โMar-17-2016 04:07 AM
โMar-16-2016 07:38 PM
fitznj wrote:
I did not see it anywhere (I could have missed it) but you don't mention a brake controller. I assume you have one fitted and that it is working. I always check the trailer brakes before each trip (listen for a humming from the brake drums).
Then for the first mile, touch the brakes and see if they are in deed slowing down the unit and that the controller is adjusted properly.
Best of luck and have fun
โMar-16-2016 12:59 PM
โMar-16-2016 11:35 AM
โMar-16-2016 08:43 AM
โMar-16-2016 07:41 AM
โMar-16-2016 07:18 AM
โMar-16-2016 07:13 AM
โMar-16-2016 07:07 AM
โMar-16-2016 07:06 AM
revco32 wrote:
I guess my real concern is this, the specs show the trailer as weighing 3250 lbs yet the label on the trailer shows a GVWR of 6150 lbs. what does this mean?
revco32 wrote:
2. Are there any tips or tricks you folks might have with regards to taking this out for the first time? I intend to take it to the high desert area where I live and there is one incline a few miles in length.
Again I apologize in advance for the possible ignorance in what I'm asking but I've read and researched this all to the point that I believe I've made myself more confused than when I started.
EDIT: I guess my real concern is this, the specs show the trailer as weighing 3250 lbs yet the label on the trailer shows a GVWR of 6150 lbs. what does this mean?
