Feb-27-2016 08:07 PM
Feb-29-2016 05:53 PM
minnow wrote:GoPackGo wrote:
Diesel - yes ?
I also have an RDS tank with the gravity flow system. They sell an install kit that includes the check valve which stops back flow. There is also a manual on/off valve on the tank. I believe in KISS.
I got the 40 gallon tank/tool box combo which fits below the rails so I can also have a bed cover. If I was doing it over I would get the 60 gallon (?) tank with the smaller tool box. It has the same footprint.
Northern Tool sells them. I suggest going to the RDS site to view all the possible tanks (there are lots). I have even read they will custom make one but have not confirmed that.
Why would you go with the 60 gallon ? I'm looking at the 40 gallon right now.
Feb-29-2016 05:29 PM
Feb-29-2016 04:46 PM
GoPackGo wrote:
Diesel - yes ?
Feb-29-2016 04:26 PM
Feb-29-2016 03:11 PM
Feb-29-2016 08:00 AM
minnow wrote:
I believe grit dog was tough in cheek responding to the post just before his.
Feb-29-2016 04:25 AM
Feb-28-2016 04:19 PM
Rangerman40 wrote:The ones I have installed have a check valve installed in the filler pipe. Shuts off fuel to stop it from running out cap.
Any big differences between the gravity fed vs the electronic controlled versions? Will the gravity fed overflow while driving?
Feb-28-2016 04:02 PM
Feb-28-2016 03:52 PM
Rangerman40 wrote:Transfer Flow have lots of supporters, but they cost a whole lot o'money. I went cheap with mine and used the money I saved to go RV'ing with. 🙂
Well, I'm 33, have no dogs in tow, and from past experiences realize most of my family can hold it longer than every 250 miles that I currently have to stop to get fuel. So yes, it's very worth it to me.
Any opinions on Transfer Flow?
Feb-28-2016 03:36 PM
Feb-28-2016 03:14 PM
Grit dog wrote:
You'll never save money with this and who cares cause once you're this old yer bladder don't last as long as a tank of fuel anyway......plus yer little sh t eater dog will tear up the upholstery if you don't walk him every 2 hours.........so a transfer tank is a total waste!
Feb-28-2016 02:57 PM
Feb-28-2016 02:35 PM
