Feb-25-2014 04:42 PM
Feb-26-2014 04:02 AM
intheburbs wrote:Mik68 wrote:
That's great info thanks, I have asked these questions and am now waiting for a reply.
How much would you pay for something like this?
An 05, with 120K miles? For $10k it should be 4wd and the LT, in good shape.
That year had two trim levels - LS (cloth seats) and LT (Leather). An even higher level is the LT with Autoride. The 6.0L engine is good, but if you're strictly focused on maximum towing ability, the 8.1L engine would be a bonus.
Here's a similar vehicle, worth about $12k because it's superclean and totally loaded - big motor, LT, sunroof, etc: CLICK HERE
Feb-26-2014 03:47 AM
Feb-25-2014 08:40 PM
Feb-25-2014 08:24 PM
intheburbs wrote:
Not sure where these numbers are coming from. The trailer you're looking at will be a walk in the park for an 05 2500.
The 2005 2500 is a beast (moreso than the one in my sig LOL). According to Trailer Life, the tow rating of that year 2500 is 9700 lbs. Rear axle rating is 5500 (limiting factor being the tires, not the axle). Payload is 2000+.
I don't think a 3.23 axle was even offered in the 2500. It's either 3.73 or 4.10, with a 6.0 or 8.1. Any of those combinations will easily handle that trailer.
Check the glove box codes -
GT4 - 3.73
GT5 - 4.10
G80 - locker (nice additional option)
1000-lb tongue weight? No problem.
7600-lb trailer GVWR? No problem.
Buy that Burb and sleep well. You'll have a hell of a tow vehicle.
Feb-25-2014 06:43 PM
Feb-25-2014 06:29 PM
Mik68 wrote:wrgrs50s wrote:
I think you meant to say the axle ratio of the vehicle. Look in the glove box of the Suburban for a factory options sheet that will have a code to indicate the gear ratio when the suburban was built.l
There is no axle ratio for the trailer, only an axle weight limit per axle like 3500 lb etc. Two axles would mean a total 7000lb capacity.
The gear ratio of the vehicle will determine the max load you can tow.
Ok, I was just quoting the words of the car salesman. I need to ask him the axel weight of the vehicle. You think he would of known that being in the industry? :h
Feb-25-2014 05:31 PM
Feb-25-2014 05:14 PM
Feb-25-2014 05:12 PM
kaydeejay wrote:
Regardless of the axle ratio - yes you are cutting it fine, but more so with the 3.23 than the 3.73.
Although you will be pushing your towing ability a little past its limits, where that 7000#+ trailer is going to hurt is the 1000# plus tongue weight. That is probably the limit of the 'burb hitch and eats up a good chunk of the available payload for the truck. Depending on how many people and how much "stuff" you plan to carry will determine whether you can stay within the truck ratings.
I for one would not want to push a truck with 120,000 miles on it too hard. I think you are asking a lot of it.
Note - not sure where the axle weights of the Aerolite comes in, it's the weight on the rear axle of the 'burb you need to keep an eye on.
Also, curiosity got the better of me - are you planning on shipping the 'burb to Oz?
Feb-25-2014 04:58 PM
Feb-25-2014 04:51 PM
Mik68 wrote:Regardless of the axle ratio - yes you are cutting it fine, but more so with the 3.23 than the 3.73.
Hello, I am enquiring about a 2005 Chevy suburban 2500 that is for sale in Dallas Texas. They are asking $9,995. It's done 120,000 miles and was a one owner vehicle with a very good Carfax history. (I am finding it very hard to find a 2500 series SUV, especially in Texas) this is our preferred choice as we need a 7 or 8 seater.
The TT we are very keen on purchasing is a Dutchman Aerolite 250KBHS with a GVWR of 7600 lbs. I asked what the tow capacity was for the vehicle and this was the response.
"The maximum towing capacity depends on the axle ratio of the trailer used. With an axle ratio of 3.23 the maxium towing capacity is 6,700 lbs and with an axle ratio of 3.73 your maximum towing capacity is 7,700 lbs."
I am waiting on a response from Aerolite for the axel weight.
How does this all sound to you guy's? And am I cutting it fine in regards to towing capacity?
