Axle Codes
patriotgrunt
I know Ford places axle codes on the door jamb sticker of every truck but does Chevy and Ram do the same? I've been helping my brother-in-law look for a truck and we can't figure out what axle the trucks have.
2015 Ford F-250, 6.7 PSD
2016 Ford Expedition, 3.5 Eco-Boost
2003 Ford F-150, 4.2 V6
Sandpiper 357 TRIP
9 REPLIES 9
patriotgrunt
Thanks for all the assistance. I find it interesting that Ram does not for certain have a sticker somewhere in the cab area that states the axle code. Seems like a lot of work to crawl under the truck to check if a code is posted somewhere underneath.
Sandpiper 357 TRIP
johntank
Took this from another site.
There are a few ways...
1. It's on a metal tag affixed to the rear diff, usually bolted through on the diff cover.
2. There may be a sticker in your glovebox.
3. Go to the link below, click on the other link, fill in the info and get a build sheet for your truck by VIN. It will tell you exactly how it was built.
http://www.ramforumz.com/showthread.php?t=71325
or could be a sticker on axle with the ratio on it.
ktmrfs
trail-explorer wrote:
THe G80 description in the link isn't entirely correct.... it's not a "limited slip"
G80 is actually a locking rear differential, the Eaton unit.
https://www.youtube.com/watch?v=tTGZOJQQBeE
yup, it's an automatically locking differential, substantially different than a posi unit in many respects
1) allows 100% torque split
2) won't engage above about 25mph
something no posi unit I'm aware of will do.
2011 Keystone Outback 295RE
trail-explorer
Bob
SoundGuy
SouthpawHD wrote:
Then you'll have to decifer the codes (Google will be helpful).
Why would the OP have to Google it? ... all he has to do is click on that link to GM RPO codes I provided. 😉
2012 Silverado 1500 Crew Cab
2003silverado
As mentioned, the code will be in the glove box.
G80 : AXLE POSITRACTION, LIMITED SLIP
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
GT4 : AXLE REAR, 3.73 RATIO
GT5 : AXLE REAR, 4.10 RATIO
mbopp
IIRR - The GM RPO AXLE codes begin with a "G"
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
SouthpawHD
Yep, glovebox will have a grey sticker full of codes. Then you'll have to decifer the codes (Google will be helpful). It'll take some time, but you'll learn all sorts of stuff about the truck.
Palomino SolAire 307QBDSK
2016 Chevrolet 2500, CC, 6.0L, 4.10
SoundGuy
patriotgrunt wrote:
I know Ford places axle codes on the door jamb sticker of every truck but does Chevy and Ram do the same? I've been helping my brother-in-law look for a truck but we can't figure out what axle the trucks have.
Any Chevy I owned including my current Avalanche this information is shown on the glove box RPO sticker.
