Jul-21-2017 08:09 AM
Sep-10-2017 09:37 PM
2oldman wrote:
I'm going to amend that to $10 or more/day. Especially when running 3 hondas in 90F for 10 hours. It's hot enough and I'm in full sun and except for 3 or 4 cycles, they run continuously. Going through 5 gallons/day.
Sep-10-2017 12:06 PM
Dennis12 wrote:
Buy a Honda 3000 inverter. Problem solved. If you maintain it it will out live you. Money well spent
Jul-26-2017 10:42 AM
2oldman wrote:I'm going to amend that to $10 or more/day. Especially when running 3 hondas in 90F for 10 hours. It's hot enough and I'm in full sun and except for 3 or 4 cycles, they run continuously. Going through 5 gallons/day.pianotuna wrote:In 90F running about 8 hours/day I'd say it's around $5/day.
Any idea of the cost per day for fuel when the air is needed?Any success with running the air from the solar?
Jul-26-2017 06:59 AM
Jul-25-2017 07:53 PM
Jul-25-2017 07:08 PM
mike-s wrote:birish21 wrote:If wired in parallel, the capacity adds, the voltage doesn't. If wired in series, the voltage adds, the capacity doesn't. In series, you'd have a 12V, 200AH battery.
If you had 2 200+AH 6V wired together would that still be 200+AH at 12V or would it go up to 400AH? Sorry for the dumb question.
Jul-25-2017 08:09 AM
Jul-25-2017 08:03 AM
CavemanCharlie wrote:
I have 2 deep cycle 6 volt golf cart batteries. As long as I don't run the furnace I am good for 3 days. Maybe 4. Running the furnace sparingly I can easily go 2 days. Maybe 3 or more.
I am just a weekend camper so I have never had the opportunity to go longer then that.
Buy yourself some good batteries. You will not regret it.
Jul-24-2017 06:39 PM
Jul-24-2017 06:25 PM
Jul-24-2017 02:28 PM
Jul-24-2017 06:32 AM
DownTheAvenue wrote:
Turn off the condensation eliminator on your Dometic refrigerator. It slightly warms the the frame between the freezer and refrigerator sections and draws a lot of 12 volt power.
Jul-22-2017 05:52 PM
profdant139 wrote:
If you have been letting your batteries run down below 12.1 volts, they might be damaged. We often get four days from one group 31 battery, without charging it at all. With a 120 watt portable solar panel, it lasts a week or more.
Please don't ask how I learned that improper battery maintenance kills the batteries. Very expensive lesson. Sigh.
Jul-22-2017 12:18 PM
