Becoming diesel gunshy
brnzbk
I have been searching for a diesel truck to pull a to be purchased fifth wheel.
After reading all of the nightmares and maintenance problems I'm concerned about future costs and down time. Do most diesel owners experience a multitude of problems or am I just seeing a small percentage that are venting? Seems to be mostly injector and fuel pump problems however, shelling out 60K for a truck that is going to need constant repairs is concerning, I hope this is the exception and not the rule.
Any experiences will be appreciated.
2015 F350 CC LB Lariat 6.7L Dually
2016 Cedar Creek 36CKTS
B&W Companion
87 REPLIES 87
TomG2
cutty72 wrote:
Because no gassers ever go to the shop???
....snips........
Sure they do. Just check it out yourself. I find a disproportionate number of diesel pickups in our local service bays. I admit that this sampling is not without its exceptions, just what I have noticed. It might simply be that they are in for longer periods of time. Also, watch this forum for the expense and quantity of repairs for the various models.
cutty72
TomG2 wrote:
Check out the repair bays at any large dealer to verify that a lot of diesel pickups spend time there. A mechanic friend won't recommend one for that reason.
Local dealership employs two good friends of mine, one a diesel tech, one a gas tech.
Diesel tech is the one of two that work on diesels that come in, and yet still is often working on gassers or other non diesel related issues.
FWIW, I have an '01 Ford with the 7.3L. I can do about any repair needed on it myself. Doubt I will ever get rid of it.
Perrysburg_Dodg
I owned a 2004 Ram Cummins and sold it with 150K no issues none and ordered a 2015 Ram Eco-diesel. Would buy mamma a Jeep GC Eco-diesel if she wanted a new vehicle, thank God she doesn't.
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
Dave_H_M
brooks379 wrote:
Just look around you next time you're driving down the road...Diesel trucks are every where !! If you are going to be pulling a 5th wheel you have no other choice. Right tool for the job !!
I tried to bite my tongue on this comment. :h What?
I have two winters under my belt with the 6.2 Ford yanking the 10K fifth wheel down the road. I had the money and the choice and chose gas and will never go back. It is each to his own. I put the extra money elsewhere.
Don't get me wrong, I do not have one negative thing to say about the modern diesels or the folks that made the choice to own one.
TomG2
Javi1
I've tried going back to a gasser after owning diesels for thirty or so years.. Nope.. not for me..
2015 Keystone Cougar 333MKS
2015 Ford F-350XL 6.7 CC, DRW, RWD
(Finally enough tow vehicle 14,000 GVWR 6062 payload)
homedad
If I towed a lot I might consider a diesel for a daily driver but for now I just don't get it. Between the higher initial cost, higher price for fuel and the crazy prices for filters and the recommended services I'll stick with a gasser. I have a 2003 diesel farm truck that I got because I was baited in by the million mile stories and potential torque. I also have 2 older diesel tractors pre-emission years. The tractors are bullet proof. But the truck was a mistake. I learned from experience that my trucks don't die from engine problems, they die from rust and everything breaking except the engine.
6_7_tow_rig
Skip the 6.0 and 6.4 Ford Powerstroke. Any other brand those years will probably be fine. Fords only after 2011.
2018 Dodge Ram 2500 Laramie Cummins 4x4
2013 Primetime Lacrosse 318bhs
path1
I am currently in a RV park that a retired Cummins guy is also staying. He worked in research, has some really good stories. Anyways he won't buy anything unless it has a Cummins. His wife has gotten used to it but wished she had a car instead of a pick up.
Made me laugh...He commented that a lot of "people want to know which truck with which diesel and I'm waiting for a Cummins to make it into a car that I like".
So he is just the opposite of Diesel "gunshy".
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
Tom_Barb
Our family old fun truck that every one gets to use is a 54 Brockway it's coming up on 600,000 miles. it gets a yearly oil change and filters it's never been apart. Every kid in the family for three generations has learned to drive it.
BenK
IMHO...it is NOT about the engine itself, but with the Bosch CP design
and from what I've read...Ford pushed the 6.0L past what their supplier
was willing to warrant in power. Of course the onerous smog stuff that
will take a few more years to figure out 'well' enough
"Well enough" as in the current constant of 'delete' and 'bullet proof'
threads here and on most of the other automotive forums I visit
After going through about a years worth of discussion and education
along the way...discussing the CP4.x design...in detail. Wonderful to
be able to dissect that on this forum
Confirms my decision to avoid diesel based on the, then, coming diesel smog
requirements
The cost of fuel is no longer as large a factor...could still make
the case on MPG...it is higher for diesel....and any given day...cost
per gallon runs +/- to even per gallon
To me, boils down to CP4 and any derivative thereof. Pure bad design
on so wrong assumptions (using diesel as both the coolant and lube
for a pump producing +20,000 PSI...the decision to NOT capture the
piston/rod/cam together...etc)
Diesel is NOT for me...
Fully admit that per unit measure, diesel has more BTU's than gasoline. Therefore
higher potential work can be had with diesel over gasoline
I'm sticking with gasoline, but willing to readdress any type of locomotive power
for my truck(s)
Plus I don't diss anyone who wishes to go diesel...like my freedom to choose
a gasser
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Turtle_n_Peeps
diazr2 wrote:
I don't understand the maintenance issues I do everything I am suppose to do to my diesel and it's still cost me hardly anything to maintain. Maybe it's because its a 2001? Don't know I just know it's a very inexpensive truck to own.
See my post about owning a good or bad diesel? Which do you think you own? Yep, you got a GOOD one!! ๐Ÿ™‚
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
jerem0621
Unless I was towing especially heavy (14k plus) I would be in a 6.4 Gas Hemi with MDS.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
trucker495
114000 miles and nary a problem.
04 HR ALUMASCAPE 31' TRAVEL TRAILER
05 RAM 3500 4X4 CTD SRW CREW CAB LONGBED
ib516
I think the auto makers have most of those issues resolved now, though there were some issues (mostly emisssions related) with the 08-11s from all 3 brands.... some more than others.
That said, after owning 2 diesels I went with gas power this time and have been happy with the choice I made.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
