โFeb-03-2018 04:01 AM
โFeb-03-2018 02:40 PM
โFeb-03-2018 01:38 PM
โFeb-03-2018 12:17 PM
gmw photos wrote:
I believe the RA08 has been superceded by the RA18, but don't quote me on that.
If you are using a 205/75-14 and if tire diameter is important ( as in you can't go bigger ) consider a 185-14. In euro size this is a 82 series section height and is just 2/10" less in diameter than your stock 205/75
โFeb-03-2018 11:33 AM
โFeb-03-2018 07:35 AM
JIMNLIN wrote:
Maxxis U-168 commercial grade in LT and 14" Euro sizes (205R/14C) a all time favorite with rv and non rv trailer owners. These are a D load range at 65 psi at 1874 or 2270 lbs capacity. Higher load and pressure rated tires require higher load and pressure rated wheels.
The last letter C is a Euro designation for a commercial class all wheel position such as cars/vans/trailers/suv.
โFeb-03-2018 06:37 AM
โFeb-03-2018 05:58 AM
โFeb-03-2018 05:21 AM
โFeb-03-2018 05:20 AM
โFeb-03-2018 04:45 AM
โFeb-03-2018 04:37 AM
bobndot wrote:
GY Endurance ST205 75 14D (2200#)
click 'specs'
https://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Endurance&sidewall=Blackwall&pa...
โFeb-03-2018 04:36 AM
โFeb-03-2018 04:23 AM
