Apr-30-2018 11:04 PM
May-03-2018 03:51 PM
May-02-2018 06:35 PM
AK Truck Camper wrote:
Shower Curtain Length
I canceled the order today for the vinyl shower curtain and bought the polyester curtain as recommended!
Thanks
Sure would appreciate any info on what to hem the height of this curtain to. As stated oringunally I’m not with the camper right now and will make a 3500 mile journey with it as soon as I’m back with it. I’ll take suggestions from anyone, but if an owner of a Bigfoot with a wet bath could measure theirs for me that would be a real bonus.
Thanks
May-02-2018 04:11 PM
May-02-2018 04:05 PM
stevenal wrote:
The panel is to thin to have much holding power with a plain screw. I use Wellnuts, which are reusable rubber expansion nuts. No sealant is needed if the hole is nice and round.
May-02-2018 03:57 PM
stevenal wrote:
Look again. That's the hose connected to the top of the mixing valve, and the other end appears to be poking out behind the metallic shut off valve attached to the wand. That shut off valve is not original, and should not be needed since there is a shutoff in the wand.
May-02-2018 01:04 PM
Could you give me some advice on “best practices” for attaching accessories to the bathroom wall in the Bigfoot. (Drill slightly under size and just screw in?)
Appreciate anyone else’s ideas on this subject also.
Thanks
John
May-02-2018 01:00 PM
So......
Just bought my 2000 2500 9.6 Bigfoot and its obvious the previous owner wasn't a fan of the showers.
The outside hose to the head is completely missing and the inside shower head is cracked and leaking (see the tape).
Thanks so much!
May-01-2018 11:14 PM
May-01-2018 10:39 PM
May-01-2018 09:46 PM
May-01-2018 08:18 PM
Thanks
John
May-01-2018 04:51 PM
TxGearhead wrote:
I would use "Command" stick-on removable hooks. WalMart.
I had a plastic liner for a shower curtain and hated it. I bought a polyester (I think) shower curtain at, you guessed it, WalMart.
May-01-2018 04:42 PM
May-01-2018 01:55 PM
Z-Peller wrote:
Over the years I have taken those shower heads off my 3 different Bigfoot's and adapted a sink sprayer hose & head. Much easier to use and conserve water dry camping.
