Nov-02-2019 07:58 PM
Nov-04-2019 07:58 AM
Nov-04-2019 05:35 AM
Nov-03-2019 08:44 PM
ken56 wrote:
Don't rely on just blowing out the lines. All the times I have winterized I blow the lines then put in anit freeze and there is a lot of clear water that comes out before the pink stuff does. Your trailer, your choice but be prepared to fix freeze damage.
Nov-03-2019 04:09 PM
Nov-03-2019 12:57 PM
Nov-03-2019 11:35 AM
Lar114 wrote:
Been blowing my water lines with air for 15 years, if you check all your faucets to be sure there is no water, just air coming out, there will be no problems with freezing water. Sure, there might be a small amount of residual water in the lines somewhere, but not enough to cause damage to lines. The one gallon of rv antifreeze goes in the traps, and the rest in the holding tanks. No problems yet. Just take your time, don't rush thru it. But different strokes for different folkes.
Nov-03-2019 11:06 AM
K Charles wrote:
We bypass the water heater, blow out the lines, open the low point drains. 25 or so years and it has frozen. Pink stuff in the traps.
Nov-03-2019 10:17 AM
Nov-03-2019 07:21 AM
Nov-03-2019 06:59 AM
jamesu wrote:
I recommend just using the pink stuff. I have never blown a line in my. 20 years of TT’ing. Have never had frozen pipes and my entire procedure takes about 20 minutes and approximately 1.5 containers of pink antifreeze. Run each faucet and shower (including the outside one) until it runs pink. It is not a tough process.
Nov-03-2019 06:49 AM
Nov-03-2019 06:32 AM
Nov-03-2019 06:20 AM
Nov-03-2019 06:16 AM
Nov-03-2019 04:18 AM
