All rechargeable battery's needs a voltage *ABOVE* their working or storage voltage
Otherwise they won't charge
The rate of charge is factored by both the voltage and amperes (inter-related)
and the higher the voltage, the faster...but can be too fast as the chemical
change from crystal will cause the chemicals to overheat and out-gas
Out-gassing is a VERY bad thing for any battery
There is a voltage regulator somewhere in your alternator circuit that maintains
the optimal voltage...normally 14.6 VDC
Have your mechanic check it out
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
