Chevrolet Silverado 3500 ambulance
mellow
Ok, not sure this will work but I am looking at buying a retired ambulance and converting it to a service body to put my truck camper on.
It is not a full on ambulance, more like an intercept with the tools in the back of it so I was thinking the back should come off and be able to retrofit a service body on it?
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
26 REPLIES 26
Grit_dog
Navigator
Navigator
Duramax with 130k on it is not a lot of miles. Being an emergency vehicle, it was pretty much for sure maintained on schedule.
Just make sure it doesn't have like 10,000hours on it. That's roughly equivalent of about 400k miles at normal driving, albeit mostly no load idling.
The rest of the truck should have a lot of life left in it.
Normal driving it would have 3500-4000hours.
Emissions issues could be costly, regardless of hours, but deleting is an option if you don't have emission testing.
As far as swapping on a pickup bed, it should be a direct bolt up. I don't think GM made a GMT 900 true chassis cab with straight frame rails in back.
mellow
2007 Chevrolet Silverado 3500HD LT2 Ext. Cab DRW 4WD EXTENDED CAB CHASSIS , 6.6L V8 OHV 32V TURBO DIESEL.
markowwes
What engine is in it?
mellow
Picture is just for reference, found it on a google search since I knew people wouldn't understand what I was talking about calling it an ambulance (which it really isn't). It is a 3500 with around 130k on it, it isn't a service body currently as it stores all the big tools in the back of it for emergencies.
I wanted to see if anyone has tackled a project like this before and if swapping to a truck bed would be easier?
jimh406
Idling isn't very good for diesels if that is what the ambulance is. I suggest a pass in spite of the picture. 😉
towpro
gbopp wrote:
d3500ram wrote:
Cheby truck??? Kinda' looks like a Ferd in the image :h
Maybe the back half is a Chevy? :B
I agree, it already looks sagged out with just that body on it.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
free_radical
Q how do you take a pig into hospital?
A in an Hambulance
Q what do you call pig without legs?
A a ground hog
mike_kellie
Keep the light kit...weight police!
2015 Host Mammoth triple slide w/ TorkLift Fastguns
2015 Ram 5500 SLT cab & chassis with Douglass 9' utility body
gbopp
burningman
Oh no that’s definitely a Dodge... 🙂
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
d3500ram
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
donn0128
Looks like a service body to me. Unbolt it, get a fork lift to lift ot off and drop on what ever you want. You will probably have dozens of wires to remove from its previous life.
