Clicking with Shore Power
Bear9350
Hello,
I just purchased a used 97 Jayco trailer. Started cleaning stuff up and getting things figured out at home last weekend. Saturday afternoon I wired up a 30amp 110 volt recepticale to plug it into shore power. I also plumbed the propane back up. I did a quick check Sat afternoon to see if the furnace and AC worked and checked most of the lights. Everything seemed good. At this point I new the battery was dead. I had previously tried to charge the battery that was on it but it would not take a charge.
Sunday when I walked into it I heard a clicking sound coming for what I assume it the converter. When I unplugged the shore power the clicking noise would slowly die out.
I did a little research online and read that the dead battery may be the problem. I purchased a new battery, fully charged it and installed it last night. Plugged it back into shore power and the clicking continued.
I am new to all this and am looking for any advice on where I should look next.
Thanks,
Brian
47 REPLIES 47
Old-Biscuit
ksg5000 wrote:
Try turning off each AC breaker one at a time and see if you can isolate which circuit is associated with the "clicking sound".
X2.......
And when you flip AC cb for converter bet the clicking goes away.
While you have the AC cb panel open check for model number of converter.
Then contact Randy at Best Converter for replacement. LINK
Doug33
My bad. I was in the middle of doing something when I made a hasty post. For some reason I saw 30 amps, but my distracted brain was thinking 20 amps. I plug in at home to a 20 amp line, and do not run the A/C.
But as everyone correctly pointed out, most campsite electric service is 30 amps, which is sufficient for A/C.
.....nevermind.....carry on..... 😉
2014 Keystone Bullet 281BHS
2002 Chevy Avalanche 5.3L 4x4
Equalizer hitch
Nights spent camping in 2015: 25
Next trip: mid-April 2016?
Hornnumb2
Mine was making some noise awhile back and when I pulled the convertor out to check it, it had sucked up a piece of a plastic wrapper and was stuck in the fan making noise.
sbowman871
If you are using a surge protector that monitors voltage, you might check the voltage at the source. Surge protectors will only allow a range of volts to the TT. The clicking might be the power turning on and off. Had this problem last year. Voltage was too hight at my pedestal. Something to consider.
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
Parkit 360
ksg5000
Kevin
fla-gypsy
Doug33 wrote:
I would not run A/C on 30 amp 110 volt circuit.
Why not?
OP-sounds like your convertor has a problem. Does the convertor fan come on when running 12v lighting?
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
T_in_Michigan
Get past the 110/120V issue. Most appliances are designed to work at 110V, 120V is the baseline voltage supplied by your Electric Utility.
Any electrician will tell you 120/240V is the voltage in your house.
Sounds like it is possible you have some loose connections or something that might be causing the clicking sounds.
2000 Chevy Suburban 2500 6L 3.73
2013 Keystone Springdale 297BHRSS
Wife and 3 Boys
Crazy Dog and 2 Cats
westend
It may be that your battery is bad and the self-resetting circuit breaker between the converter and the battery is opening and closing. Remove a cable from the battery to verify.
'03 F-250 4x4 CC
Dennis_Smith
I thought all campers were 120 volts, and I bet 90% are 30 amps. Mine works great with air, microwave, and everything else on with 30 Amp ckt
Bear9350
beemerphile1 wrote:
The refrigerator and furnace ignition clicks.
I am fairly certian I have both of those of but will double check this afternoon.
Bear9350
Dave5143 wrote:
Is it possible that your rig has an Electrical Management System installed somewhere inside?
I have one in my trailer and if the power source is unable to provide full current to the load (mine was routed through an electronic timer switch to power the fridge overnight before leaving home) then the contactor inside will click furiously to try to shed the load from the power as the input voltage drops.
I now use a dedicated circuit for the trailer when at home though it is still limited to 20A.
Not sure if I have a management system. It doesn't sound as if this would be the problem though if I am reading your response right. My clicking doesn't seem to change. It will click when I have no lights/ etc and the clicking doesn't change when I turn a few lights on and the AC.
Bear9350
enblethen wrote:
Welcome to RV.net!
Sounds like a capacitor is failing.
Make and model of converter?
Not sure on the make/ model of the converter. I will check when I get home from work this afternoon.
Capacitor would make since. It does sound similar to the noice I have heard from other failing capacitors. It would also makes since how the noise lessens as the capacitor discharges.
enblethen
Voltage is actually suppose to be 120 volts AC from utility.
Then premises installation causes voltage drop.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
beemerphile1
What would you use? Tens of thousands of RVs have 30a 110vac service.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Dave5143
Dave & Mary
2012 Denali 289RK
Ford F250 Lariat Powerstroke 6.7L Diesel
