โMar-26-2019 06:44 PM
โMar-28-2019 06:15 AM
travelnutz wrote:
Seems there's something you do NOT understand. Max HP is measured at or very near max engine RPM and virtually no one drives or pulls a load towing anywhere near the engines max RPM. Diesels OEM pickup engine max torque is at 1500 to 2000 RPM and that's right where the tow vehicle diesel max torque occurs and where diesel pickups etc run at on the highway towing or not towing.
Revving an engine at or near max RPM to have mass movement of the engines heavy components really only greatly increases fuel consumption per distance made good.
Smart people use the vehicle lower gearing and keep the RPM's as low as reasonable around max torque value to get the most desirable power out of the engine. Especially with a diesel engine. Yes that means slower speed ascents on grades and using the lower gearing to multiply power delivered to the drive wheels but that's only on the way up and then return to higher gearing when on flatter ground. OR, use the engine's higher compression to help control the speed going downhill with the lower gearing and close to virtually no fuel being used.
HP is only a calculation not a measured reading and must have engine's known torque and RPM's values to calculate. HP = known measured engine RPM's times the known torque value divided by 5252 or there's no HP number. It's only torque delivered to the drive wheels which turns the drive wheels RPM's in contact with the road surface to the propel the vehicle to the desired vehicle velocity. Also NO loss of power with altitude gained with a turbo diesel but roughly 3% loss for each 1000 feet above sea level with a normally aspirated (non-turbo) gas engine.
What it means is virtually all vehicles make it to the top of a steep grade or mountain and even with the smaller engine only adds maybe 10 to 30 seconds to a climb of the mountain's grade. Hardly requires a lot of patience! 240 ft lbs of torque will pull about any load up a mountain by just using proper gearing for the multipliers. Virtually all OTR 18 wheelers have very low HP values but have very high torque values and they can pull 100,000 lbs right up the mountains constantly and get to their same destination as you within minutes or the high HP towing vehicles because there's speed limits for safety anyway on roads.
โMar-28-2019 05:46 AM
โMar-27-2019 09:44 PM
โMar-27-2019 07:04 PM
โMar-27-2019 05:13 PM
โMar-27-2019 03:48 PM
โMar-27-2019 11:06 AM
โMar-27-2019 06:40 AM
โMar-27-2019 06:08 AM
d1h wrote:
They claim it has towing power but does it have as much as my 5.3 gasoline full size Silverado?
โMar-27-2019 05:46 AM
โMar-27-2019 04:41 AM
โMar-26-2019 11:43 PM
โMar-26-2019 10:30 PM
โMar-26-2019 09:59 PM
