Depends on the size/length of the crack. Sounds like it may be minor. If so, after removing the tap set, I would drill a small hole-maybe one eighth inch-at the end of the crack so that it won't run anymore; "vee" out along the crack with a Dremel or v-file; fill the crack with epoxy; sand smooth with 220 grit or finer after epoxy sets.
Replacing the shower surround could be a big job involving more than just the surround.......damage to walls, new taps, modify water lines, etc.
In my mind, and without seeing it, I would go with the repair unless you have the aptitude/ability to replace it yourself.
Good side is that it won't leak, bad side might be that the colours may not match.........
Hope this helps...........
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
