Crack in plastic shower wall Lance 1172
Geterdone
We noticed a crack running along the wall of our shower just below the spigots and runs to curve on back wall. Is there a practical way to repair this or must the shower walls be replaced ? This is in a 2013, Lance 1172.
Steve and Patti, 2014 Ram Duelly, Longhorn Laramie, Lance 1172 solar,Genset, torklift super hitch, and tiedowns, Bodiak front hitch,Polar Kraft boat when trailered.
10 REPLIES 10
bighatnohorse
Check the basement area under the shower. My 2014 1181 had shims under the shower pan that had fallen out. I caught that defect before it became a bigger problem.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
โ€œThe best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
mkirsch
Nomad II
Nomad II
Is it fiberglass or some sort of acrylic?
In my experience NOTHING sticks to acrylic. Had a cracked shower pan in my TC. Tried epoxy, no dice. Fiberglass and resin, fuggeddaboutit. No amount of roughing and cleaning would make it stick. Like eggs off a teflon pan.
If fiberglass, you've got it made.
Buzzcut1
Nomad II
Nomad II
Places that do Fiberglass boat repairs can probably fix that right up for you and make it look good.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
StirCrazy
Moderator
Moderator
do you need it pretty? or just functional. I had one appear in my suround and I found the almond Geocell calking did a fine job of sealing it up and holding it togeather.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
d3500ram
I had a crack in the base of my last camper and this is what I did:
I drilled a hole at the end/ apex of the crack in hopes any forces would disperse around that hole and not continue further.
I filled the crack/ drilled holes as best I could with flexible caulk and applied an appropriate size piece of trimmed- to- fit EternaBond over it.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
bukhrn
The one in my Class C did the same thing, i fixed it with epoxy, I'm not a pro, and it doesn't look like a pro did it, since DW and I are the only ones that have to look at, it really doesn't matter all that much, but it worked.
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
ticki2
There are also folks who socialize in this . Look up shower an bathtub repair near you
'68 Avion C-11
'02 GMC DRW D/A flatbed
ssthrd
Depends on the size/length of the crack. Sounds like it may be minor. If so, after removing the tap set, I would drill a small hole-maybe one eighth inch-at the end of the crack so that it won't run anymore; "vee" out along the crack with a Dremel or v-file; fill the crack with epoxy; sand smooth with 220 grit or finer after epoxy sets.
Replacing the shower surround could be a big job involving more than just the surround.......damage to walls, new taps, modify water lines, etc.
In my mind, and without seeing it, I would go with the repair unless you have the aptitude/ability to replace it yourself.
Good side is that it won't leak, bad side might be that the colours may not match.........
Hope this helps...........
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
daily_double
I had the same thing happen in another camper. Took it to a good fiberglass repair place and it looked as good as new!
pianotuna
Nomad III
Nomad III
It is possible to weld the crack.
Regards, Don
