Diesel draw
Andymon
Anyone know how much the draw is when you have a diesel plugged into 110v when it's cold?
2008 Springdale 266RLS
1999 F250 7.3
Medford, Oregon
14 REPLIES 14
Moose10
My '01.5 CTD block heater is 800W, plus I have 2 150W oil pan pads and a Napa trickle charger. Never felt the need to put anything on the NV5600 even at 50 below. Anyway, at those temps nothing runs smooth for a while.
2001.5 Ram 3500 4x4 QC Sport ETH/DEE
on Vision Hauler 19.5's
'06 Arctic Fox 1150
'09 Nissan Murano S
'14 Ford F-150 FX4
'03 Polaris 700RMK VE, MBRP can
'04 Polaris 600RMK VE
'04 & '05 Suzuki Eiger 400's
C_Schomer
My old NTC was 750W. My 97 CTD was ~300W. I don't know what my 03 has. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
dmax_83
750w is what the block heater on my duramax draws.
1998 Jayco Eagle 302FK (Honda EU3000is)
2016 GMC Sierra Denali 3500HD 4x4 Duramax/Allison
2003 Honda Aquatrax F-12X Turbo
4x4ord
My 6.7 Ford doesn't draw much. I think I plugged it in only once in three years.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
RinconVTR
Every RV'er and Home owners needs one of these:
Kill-A-Watt
lenr
2011+ Ford 6.7 is 1000 watts, 8.3 amps at 120 volts (meter measurements agree). Owners manual says engine temperature stabilizes at 3 hours so I have a timer set for 3 hours before leaving for work.
ScottG
They draw 700 to 750 watts.
Even the big rigs dont draw 1500.
jus2shy
The manual for my truck states 6 or 7 amps of power draw for my motor's block heater. I have it on a timer, so 3 hours before work it's pre-heating the engine block on my truck. By the time I go to start it, it's roughly 100 degrees in the cylinder head in an ambient temp of 14 to 20 degrees farenheit.
E'Aho L'ua
2013 RAM 3500 Crew Cab 4x4 SRW |Cummins @ 370/800| 68RFE| 3.42 gears
Currently Rig-less (still shopping and biding my time)
K_Charles
I believe the 7.3 Powersmoke came with a 1500w block heater.
boogie_4wheel
They fall in to the neighborhood of 750W.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
JamesBr
If you mean the block heater for a 7.3 ford diesel? I have seen between 6-8 amps drawn depending on the extension cord and voltage at the supply side. I am plugging in at a campground I try to home run directly to the pedastal rather then through the camper.
2006 Ford F350 6.0
2014 Primetime Sanibel 3600
Enough other vehicles to not bother listing.
Previous RV: 2001 Monaco Knight
powderman426
gmcsmoke wrote:
1.21 jigawatts
http://www.dieselplace.com/forum/63-gm-diesel-engines/20-6-2l-diesel-engine/540818-whos-good-math-co...
That must be why I bought the flux capacitor.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
2oldman
About 1200w
