โJul-08-2017 12:54 PM
โJul-10-2017 02:24 PM
ducksquasher wrote:
Hey All,
Looking at stepping up to a new truck and a diesel for the first time. I am looking for guidance on exhaust brakes and any differences between GM, Ford and Dodge?
Thanks in advance!
โJul-10-2017 09:11 AM
IdaD wrote:
...I like the two settings the Cummins has. Towing in the Rockies, Cascades and Sierras out west it has worked really well to the point I only need to brake in situations where I'm approaching a corner and need additional slowing - just going down a grade it'll hold speed by itself. I generally use it in auto mode along with tow/haul.
โJul-09-2017 07:44 PM
boshog wrote:Walaby wrote:
On my 2015 Ram 2500 the exhaust brake and tow/haul are both off by default. Have to push exhaust brake once for full, second time for auto. I usually tow in auto.
Mike
If my trailer is connected to my truck (2015 RAM 3500 Cummins) when I switch on the ignition, and the exhaust brake and tow/haul was enabled on the last ignition cycle, the exhaust brake re-enables but the tow/haul mode will not.
If I do not have the trailer connected, then regardless if the exhaust brake or tow/haul were enabled on the last ignition cycle, they both are off on the next ignition cycle.
โJul-09-2017 07:33 PM
Cummins12V98 wrote:
"when I switch on the ignition, and the exhaust brake and tow/haul was enabled on the last ignition cycle, the exhaust brake re-enables but the tow/haul mode will not."
This is CORRECT!
โJul-09-2017 06:19 PM
โJul-09-2017 06:18 PM
lc0338 wrote:AH64ID wrote:tinner12002 wrote:Cummins12V98 wrote:lc0338 wrote:
RAM exhaust brake is on all the time. Tow/Haul mode is selectable
WHHHHAAAATTTTT??????
I think he just forgot to add that full exhaust mode is also selectable as the exhaust brake in auto mode is always on and available.
You can turn off auto mode as well.
Yes, when I start the truck the exhaust brake is on but tow/haul is off. I have to turn on (push button) for tow/haul mode. I actually run with two/haul mode on even when not towing because it so easily slows the truck and use of foot brake is greatly reduced ๐
โJul-09-2017 06:17 PM
โJul-09-2017 06:05 PM
Mike
โJul-09-2017 04:07 PM
โJul-09-2017 03:59 PM
โJul-09-2017 07:37 AM
โJul-09-2017 07:29 AM
โJul-09-2017 07:24 AM
โJul-09-2017 07:16 AM
