Nov-30-2013 07:24 AM
Dec-17-2013 06:58 PM
Passin Thru wrote:
I have run heavy trucks 2.4 million miles and CAT and Cummins can both go stick their advice. Even with the truck running, had a 500 HP CAT which was supposed to feed hot fuel into the right tank, drawing it out the left tank and supposedly circulating it via a crossfeed tube between the bottoms my fuel line froze and I was stranded in Wy on I 80 in -12 windy weather. I walked to a store, bought all the Power Service they had and thawed it enought to run 30 mph for 50 miles. It was a cold lesson and I always use Power Service in the winter now.
Dec-17-2013 06:45 PM
Dec-17-2013 01:39 PM
Dec-11-2013 10:22 AM
phenrichs wrote:
I use Power Service exclusively. Grey bottle until temps hit 20 degrees and stay there. Then it is white bottle till spring returns.
Dec-11-2013 01:44 AM
2oldman wrote:calamus wrote:I'm way more skeptical of what my buddies do.
Im always skeptical of studies who paid for it?
Dec-10-2013 10:59 PM
Perrysburg Dodgeboy wrote:TxTiger wrote:
I use Opti-lube in my 2000 7.3. Very inexpensive and provides great lubrication. They've just come out with a cetane booster version.
How do you like it, i have looked at them and was wondering how good there products were. Looks like I will give them a try.
http://opti-lube.com/diesel-fuel-improver-summer.html
Don
Dec-10-2013 06:08 PM
hotpepperkid wrote:
I run Stanadyne or the stuff Ford sells in the winter, quits it down on start up
Dec-10-2013 04:14 PM
Dec-09-2013 09:06 AM
Dec-05-2013 05:50 PM
Perrysburg Dodgeboy wrote:You may be right, but it may be another 150-200k and 10 years before it happens. You bet your way, I bet my way. But the way some folks talk it should have died 100k or more ago. Oh well.john&bet wrote:Perrysburg Dodgeboy wrote:And just when do you think my 10 year old, 160k, '04.5 truck will die? Never a drop of additive in it.
You guys that think adding "lubricity" to "ULSD" is not needed in older per 07 trucks, are out of your minds. Older diesels are designed to run on standard diesel as in high sulfur content. Run your per 2007 diesel without adding some kind of lube to the fuel and you WILL be replacing your injection pump and injectors.
OP adding non-syn 2 cycle oil to your fuel will keep your diesel happy.
Here is a link to a site that has done a lot of research on it.Link
BTW there is not #1 or #2 diesel anymore, ULSD does have a winter blend or extra anti-gelling additives but that's it.
Don
BTW go to any of the real diesel engine manufactures web-sites and see what they are saying if you think it's just "marketing" ! :R
Hay it's your truck and your the one that will be paying the repair bill if needed. Me I would rather be proactive and not reactive . I hope your never dies and runs forever, as I hope the same for my truck. If adding extra lube can help it get there whats the problem?
Don
Dec-05-2013 04:03 PM
Don
Dec-05-2013 01:36 PM
Don
Dec-05-2013 08:11 AM
Don
Dec-04-2013 02:36 PM
