โJan-18-2014 06:28 AM
โJan-20-2014 09:42 AM
CB
Channel 17Redneck Express
โJan-19-2014 08:16 PM
โJan-18-2014 11:45 PM
โJan-18-2014 08:11 PM
โJan-18-2014 05:43 PM
โJan-18-2014 01:42 PM
Photomike wrote:
Around here the winds are a steady thing most times of the year, like others have said if you can wait it out.
If you have the option try to drive in the morning or evening or even at night as they tend to lessen then.
If you have to drive in winds drop your speed down, pull over often to let faster traffic pass and take rest stops to let your nerves calm down. I will actually take more back roads so I can really drop my speed down.
Things to be careful of is if you have a cross wind and a vehicle is passing you. If that vehicle is bigger than you be careful that you do not get sucked into the other lane. If you are bigger be aware that someone may get sucked into your lane and be prepared to react. Same goes for being in open areas, passing a row of trees or buildings can cause you to suddenly be traveling side ways either off the road or into the next lane.
โJan-18-2014 01:20 PM
Victory402 wrote:
What would you gentlemen consider a safe cutoff point, for wind speed, for the average TC?
โJan-18-2014 01:06 PM
โJan-18-2014 12:28 PM
โJan-18-2014 11:16 AM
snowdance wrote:
We also live in an area where 40-60mph winds are common. Many of the roads we travel are made so the road bed ends at the edge of the pavement with no shoulder and may have a 10 to 60 foot drop there with no guard rails. And we do have to drive our small MH in them or set 40-50 miles from home for days. What did help us was running the rear tires up to max side wall listed pressure. We added a rear sway bar (our MH came with a nice heavy front sway bar) and it made a big difference. Also get a loaded weight on the rig by axle or wheel if you can. You can find charts showing how much air pressure you need to run for the weight on the front. Play with that some. We run less than listed for my rig but it steers and handles very well. We also seek back roads when we are forced to travel in the high winds as then we can move at our speed. It becomes a must to be able to change the air pressure in the rear tires so you will need to stop some place you can do that or carry a small compressor. Running them up that high when not in the winds might be a problem making it harder to drive and ride harsh unless you need that much..
โJan-18-2014 11:13 AM
โJan-18-2014 11:02 AM
โJan-18-2014 09:40 AM
โJan-18-2014 07:57 AM
