โSep-22-2015 09:43 AM
โSep-26-2015 09:44 PM
gbw wrote:
I could always bump up to 19.5's and suffer with the unloaded ride.
โSep-24-2015 07:39 AM
โSep-23-2015 03:14 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โSep-23-2015 01:19 PM
โSep-23-2015 12:59 PM
โSep-23-2015 09:29 AM
โSep-23-2015 08:23 AM
boogie_4wheel wrote:Then you need rear fenders, about 500 to 600 each (new), or a duely bed at 1200 to 1800 (used) or a flatbed steel about 500 to 1000 or aluminum at 2400 plus. Add to that the cost of 6 wheels and front adapters.
I'd keep the Dodge you've got, and go DRW conversion.
Get the front hub adapters. The DRW axle is a little wider for tire/frame/wheel well clearance, so you would need to run wheel spacers (sucks cuz you are doing this for weight carrying), or swap for a used axle.
Toad: 91 Zuke
โSep-22-2015 04:50 PM
pcoplin wrote:
I really think it depends on what performance you prefer. I'm a gear head, and modify most every vehicle I've ever owned.
I have a 7.3 Ford tuned as high as the stock injectors will go. It's okay, but it doesn't compete with a newer truck, stock or tuned. I couldn't deal with a gas engine.
But I also have a 5.9 Dodge V8 in my Jeep Wrangler...
โSep-22-2015 04:34 PM
โSep-22-2015 03:36 PM
โSep-22-2015 03:10 PM
Super_Dave wrote:pcoplin wrote:
If you had the diesel, you will likely be wanting more. The 5.9 far surpasses what a small block gasser can do.
And is that $37,000 for a 2006 with a gas motor? You can do way better down here buying a diesel I think.
Think it is either a typo or he got the exchange rate wrong.
โSep-22-2015 02:40 PM
โSep-22-2015 02:22 PM
โSep-22-2015 01:51 PM
