Jun-10-2015 08:42 AM
Jun-10-2015 12:39 PM
Old-Biscuit wrote:hohenwald48 wrote:
I installed one and it worked just fine. I can't imagine why you would need to remove the WH and drain and flush? I never did that and it worked just fine for the 6 years I had it.
Need to remove the 'heating element' out of drain hole and flush WH tank routinely as part of WH maintenance.
That is one reason WH mfg. will void factory warranty cause folks don't do routine maintenance after installing the after market kits.
Jun-10-2015 12:30 PM
Jun-10-2015 11:33 AM
Jun-10-2015 11:10 AM
Jun-10-2015 11:04 AM
Jun-10-2015 10:59 AM
Jun-10-2015 10:33 AM
Jun-10-2015 10:11 AM
Jun-10-2015 09:39 AM
Jun-10-2015 08:46 AM
